Author Topic: Shure BLX Wireless Microphones - Are they really that bad?  (Read 2225 times)
Simon Barz
    • Channel Audio
« on: March 10, 2019, 08:15:29 pm »
Hey Guys,
I am in the market for some wireless handheld microphones for AV hire use. Mostly corporate gigs at smaller venues and no more than (4) mics at a time.
I've been doing some research and see a lot of negative comments from the pro community regarding Shure BLX. I don't know much about RF and was wondering if any of you all could help me understand if/why they are a poor option.
Thanks!
Channel Audio - AV Equipment Rental & Event Production
https://www.channelaudiogroup.com/av-services
William Schnake
    • Schnake Sound & Light
Re: Shure BLX Wireless Microphones - Are they really that bad?
« Reply #1 on: March 10, 2019, 08:26:05 pm »
Simon, I just bought 4 BLX, I generally use either ULX/P or QLX-D.  Anyway, I used them last week for a conference in a small breakout room and they worked fine.  They are not a high end mic, but they worked just fine for the conference that we were doing.  I am also going to use them for school rentals.
Bill
Bill Schnake - Owner Schnake Sound & Light
Avid/Crown/EAW/EV/Midas/RCF/Shure/Yamaha
schnakesound.com
David Allred
« Reply #2 on: March 10, 2019, 10:25:12 pm »
Bill
I put one in an install several years back.   It works at ranges up to 125 ft through 2 cinder block walls.  Standard antennas only.
Debbie Dunkley
  • Central North Carolina
« Reply #3 on: March 10, 2019, 11:17:05 pm »
I have a BLX system ( a couple actually).
I sing backing vocals from FOH and I got myself a good quality AKG headset mic to use with the pack and it has been great.
I get no problems with drop out and latency is no more noticeable than with any other wireless mic I have come across.
It is of cheaper build - plastic and quite basic but it has everything I need and gets the job done.
Taylor Hall
« Reply #4 on: March 11, 2019, 07:34:26 am »
Keep in mind that there are two flavors of BLX, one that is a plastic receiver, and one that is metal. The metal version, while more expensive, allows you to use external antennas and gives you more info on signal quality, audio level and battery life.
We have several channels of the metal receviers and haven't had any issues with them. Really the biggest drawbacks are that the mic capsules aren't swapable and the receivers don't interface with WW, so coordination is a bit of a shot in the dark. The method these mics use to find their channels seems to work well enough to prevent crosstalk, though. We only had to swap channels once when we were doing an event alongside about 5 others in a conference center, lots of RF flying around that day. Similar to Bill, we use these as our "budget" wireless setups as the sound is perfectly acceptable and are cheap enough to replace should something go wrong.
1) Do it right
Debbie Dunkley
« Reply #5 on: March 11, 2019, 09:26:39 am »
Yes - there is a metal bodied receiver and a plastic one. I have one of each and I have found them to be as reliable as each other. In fact I have found the plastic bodied receiver to be less prone to interference from other RX /TX equipment in the same rack. However, I can take my antennas from the metal unit and move them to a more suitable location which of course I cannot do with the other one.
The packs are plastic regardless of which receiver you choose but I did drop one of mine one time on a hard floor and it survived (surprisingly).
lindsay Dean
« Reply #6 on: March 11, 2019, 11:08:34 am »
 small drawbacks to entry level is the capsules are not interchangeable
     and Pray for higher guidance
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
« Reply #7 on: March 11, 2019, 11:28:12 am »
Also, they often can have a smaller number of units in a single system.
Taylor Hall
« Reply #8 on: March 11, 2019, 12:44:00 pm »
BLX is limited to 12 channels per band, but for an entry level system that's pretty snappy. That's triple the max channels of their entry level digital lines (though I think the new digital "advanced" lines bump that up a bit) since not everyone can quite stomach $1k+ per channel for Q/ULX or Axient... I can't think of many small band or HOW scenarios that would encroach on that limit, even if every band member had vocals along with a couple belt packs for instruments. Maybe if you had a fleet of Debbies for backup singers, though ;)
Pretty sure the other non-digital lines from Shure have a similar limit, but they also allow you to "combine" additional bands to get you up somewhere in the 20s for usable channels.
1) Do it right
Steve Litscher
    • MixMasters Podcast
« Reply #9 on: March 11, 2019, 03:22:55 pm »
I have (and am selling) a BLX system with dual PG58 handsets and dual-channel receiver. It has worked flawlessly the 4-5 times that I've used it. For the $$, it's pretty tough to beat.
Would I use it for lead vocals in a band, or if I had to coordinate a ton of RF? No. But it works really well for talking head/emcee use. Battery life is great, range is good, and they seem reliable.
My only complaint is the "on/off/mute" button on the handheld. If it had a switch, rather than a push button, they'd be perfect.
Page created in 0.027 seconds with 25 queries.
