Author Topic: Does sub cabinet weight affect low end response?  (Read 864 times)
bvdd
« on: February 05, 2019, 06:53:27 pm »
I build Thiele design 15" cabinets using 3/4 plywood for subs which work great for what I do.
I use the same model 8 ohm speakers and all dimensions both inside and out are identical.
On stage, I use two cabinets crossed over at 100hz, powered by a Crown XLS 1502 in bridge mode - 1500w @ 4 ohms.
I've noticed that some 3/4 plywood weighs noticeably more than others.
Would the lighter vs. heavier plywood weight difference affect the bass response and perceived volume of the cabinet?
If so, how much of a weight difference before I notice?
Thanks.
Page created in 0.067 seconds with 22 queries.
