Author Topic: Truss leveling system  (Read 1050 times)
Magnus Högkvist
« on: January 26, 2019, 12:07:22 pm »
Does anyone know if there is a leveling system for trusses? We have a truss grid with 8 motors. The idea would be to have a distance sensor at each rig point to be able to see that grid is leveled. Of coarse this also means that all sensors must to be connected to some form of computer or monitor.
Interested to see if anyone has any ideas.
Mark Cadwallader
  • Helena, Montana USA
Re: Truss leveling system
« Reply #1 on: January 26, 2019, 02:11:11 pm »
Motion Labs seems like it may have what you are looking for.
Magnus Högkvist
« Reply #2 on: January 26, 2019, 03:21:24 pm »
Thanks and interesting, but it's only for Motion Labs controllers and CM motors and I'm looking for a more generic solution.
Mark Cadwallader
« Reply #3 on: January 26, 2019, 04:12:47 pm »
Do you need exact distance from deck to grid, or is the grid being level sufficient?  X-Y levels might be an answer, as well as an optical/light beam sensor setup.
Do you want a DIY solution or a COTS solution?
Richard Turner
« Reply #4 on: February 01, 2019, 10:12:40 am »
rotary laser level.
4 half cheesebouroughs with a metal ruler bolted to them
Looking at retiring. Local PA market has shrank to 2 guys with guitars and bose l1 compacts or expecting full line array and 16 movers on stage for $300... no middle left going back to event DJ stuff, half the work for twice the pay.
Magnus Högkvist
« Reply #5 on: February 01, 2019, 12:14:48 pm »
rotary laser level.
Thanks guys, I have been thinking in the lines of a rotary laser and then just check one corners hight, problem is the grid is not a square or rectangle so if one motor is low it might not be that easy to spot it.
But really all this is just because our light guy is a bit lazy....
Len Zenith Jr
« Last Edit: February 01, 2019, 04:02:24 pm by Len Zenith Jr »
« Reply #6 on: February 01, 2019, 03:38:57 pm »
Page created in 0.027 seconds with 22 queries.
