Author Topic: Par can DMX problem  (Read 459 times)
dmarin
Par can DMX problem
« on: January 03, 2019, 09:24:14 pm »
Hello, I own a cheap standard 512 DMX controller and 4 brand new (cheap Chinese) par cans.
The par cans are working properly standalone without DMX, but when I connect them to the console no signal and no control to the lights!
The cable is DMX, the address is correct, and I use also a terminator with 120ohm resistor.
The console also has a polarity switch but no luck!
I forgot to mention that I test once at a time and not all together! Also the console is working properly with other "more expensive" lights as ADJ etc.
Please your help!!
Thanks!
Jeff Lelko
  • Cape Canaveral, FL
Re: Par can DMX problem
« Reply #1 on: January 03, 2019, 09:43:06 pm »
Hi there.  Before anyone can help you'll need to change your username to your actual first and last name per the policy you agreed to when signing up.  Until you do that no one will be able to offer assistance.
Thanks!
Page created in 0.035 seconds with 22 queries.
