Author Topic: Circuit Breaker plug  (Read 1035 times)
Frank DeWitt
    • LBP DI Box
« on: November 26, 2018, 06:52:22 pm »
A Circuit Breaker is built into the plug.  If it trips, it unplugs it self!
For my collection only.  Not to be used.
Not to Code
Re: Circuit Breaker plug
« Reply #1 on: November 26, 2018, 06:57:21 pm »
Frank, your finds continue to surprise and impress.  That's *really* cool!
Frank Koenig
« Reply #2 on: November 27, 2018, 12:57:45 pm »
Very cool, indeed. A non sequitur, but this reminds me, for some weird reason, of a cable tension failure detector I saw on a ski lift on Mount Ashland, OR last summer. At the top of the hill there is a huge, ugly chunk of concrete that serves as the tensioning weight for the main rope. Attached to it was a funky, rotting cord and plug arranged so that if the weight moved outside of a certain range the plug would unplug and, presumably, ring a bell or something down at the control panel. Somehow I don't think this lift was made in Switzerland. -F
« Reply #3 on: November 27, 2018, 01:51:48 pm »
It likely unplugs the lift motor.  Probably designed by snow skiing engineers in Lower Alabama and built by Northern South Dakotans from Hoople, SD.
« Last Edit: November 27, 2018, 03:34:54 pm by Tim McCulloch »
Mike Caldwell
  • Covington, Ohio
« Reply #4 on: November 27, 2018, 03:33:36 pm »
That sounds like a Rube Goldberg invention!
« Reply #5 on: November 27, 2018, 04:36:17 pm »
My pressure washer has a GFCI built into it's plug. My in-wall heatpump/airco has some sort of a smart plug... with "test" and "use" buttons.
I have seen plugs that sense for leakage to ground and disconnect (different than GFCI).
[edit- I read the OM and my airco has one of those leakage plugs... apparently it's an UL thing protecting against squashed line cords. [/edit]
« Last Edit: November 28, 2018, 09:32:51 pm by John Roberts {JR} »
Lee Douglas
  • 47.662615, -116.756954
« Reply #6 on: November 27, 2018, 09:07:43 pm »
I keep envisioning someone "fixing" that with plumbers tape and a couple drywall screws because, "The damn plug keeps falling out!"
This space for rent
Jonathan Johnson
« Reply #7 on: November 28, 2018, 02:03:11 pm »
Years ago, one of my dad's shop buildings was in danger of collapsing -- I think it was the Romex leading into the building that was holding it up. I braced the bulding best I could. I had planned to wire the Romex with a plug and receptacle so it would unplug itself if it did collapse.
But, life got in the way, I moved away, and eventually my brother tore down the building, so my "self-unplugging disaster" never happened.
Kevin Conlon
  • Thanks for being here
« Reply #8 on: November 28, 2018, 08:37:04 pm »
OMG i have one of those, without the box. Once apon a time it was a good idea. (i tested it, it worked!)
Page created in 0.04 seconds with 22 queries.
