Author Topic: Enabling PoE on a Cisco SG300/10 for a Dante AVIO unit?  (Read 5937 times)
Kirby Yarbrough
  • Reston, Virginia
« on: November 06, 2018, 05:05:24 pm »
Just acquired a Dante AVIO 2-ch analog output adaptor, and I can't get it to speak to me.  From what I've read, it's likely because it needs PoE, but the links I've found to enable PoE on the SG300/10 come back with some version of 'article not available'.  The SG300 specs say it will provide PoE.
Anyone know how this is done, or if I'm chasing the wrong solution altogether?
John L Nobile
Re: Enabling PoE on a Cisco SG300/10 for a Dante AVIO unit?
« Reply #1 on: November 06, 2018, 05:15:51 pm »
Depends on which one you have. I have a bunch of 8 port ones that don't. Check out this list
https://www.cisco.com/c/en/us/products/switches/small-business-300-series-managed-switches/models-comparison.html
Single channel POE injectors are cheap.
Caleb Dueck
« Reply #2 on: November 06, 2018, 06:43:57 pm »
Yamaha has a great article about how to configure an SG300 for Dante.
SG300-10 doesn't have PoE, while the SG300-10PP does.
Kirby Yarbrough
  • Reston, Virginia
« Reply #3 on: November 06, 2018, 08:37:34 pm »
Yeah, finally found that answer.  Oh well, in the market for a PoE injector.
Bryan Hargrave
  • I'm one jammin' dude.
    • Soundworks of VA, Inc
« Reply #4 on: November 07, 2018, 01:02:08 pm »
Just make sure its 48v and not 24v. I have a ton of Ubiquiti Edge POE switches and a few of the injectors for their APs. They just don't kick out the juice to power the Audinate stuff... or most non-Ubiquiti stuff.
You should be able to find something on Amazon for 15-20 bucks. The TP Link TL-POE150S will work just fine. If you plan to expand to more of the AVIO units I would suggest getting a switch to power them instead. Having multiple injectors and their wall warts gets messy fast. I have a Netgear Prosafe GS110TP that powers 2 AVIO, an AP and another switch. I got it refurbed for just under 100 bucks.
Like us on facebook at Soundworks of VA, Inc.
Russell Ault
  • Edmonton, AB
« Reply #5 on: November 07, 2018, 02:37:02 pm »
Not sure about the switches, but aren't the Ubiquiti injectors explicitly proprietary (like, in a "might let the magic smoke out if you plug them into a non-Ubiquiti device" kind of way)?
-Russ
Bryan Hargrave
« Reply #6 on: November 07, 2018, 03:47:23 pm »
That could be, I don't really know. But the marked output on the hardware says 24v which is pretty suggestive that the biggest issue is just that there isn't enough voltage to power the AVIO which requires 48v.
-Russ
William Schnake
    • Schnake Sound & Light
« Reply #7 on: November 07, 2018, 04:45:34 pm »
-Russ
This is just a thought, but we have been using Ubiquiti for several years and the easiest way to do it is to use PoE.  If it were me, I would get a PoE supported switch.
Bill
Bill Schnake - Owner Schnake Sound & Light
Avid/Crown/EAW/EV/Midas/RCF/Shure/Yamaha
schnakesound.com
Samuel Sjöbergsson
« Reply #8 on: November 08, 2018, 12:52:28 am »
But the difference isn't only the voltage ubiquiti own 24v is passive which means it always 24v while the standard 48v is active and only have power if the receiver wants POE. That said I don't know about the edge-switches but the bigger unifi switches with POE has support for both standard 48V and thir own 24V but to use 24V you need to activate it on that port.
Doug McFadzen
« Reply #9 on: November 08, 2018, 10:18:54 am »
Make sure that your PoE injector is Class 1 802.3af PoE per the manufacturers specification.
https://www.audinate.com/products/devices/dante-avio#analoginput
Page created in 0.043 seconds with 21 queries.
