Author Topic: Intermitent buzz through all sound devices  (Read 4594 times)
Dave Garoutte
  • San Rafael, CA
Re: Intermitent buzz through all sound devices
« Reply #10 on: November 06, 2018, 12:01:36 pm »
I have a high tension line outside my shop that causes a buzz in my bass preamp when the humidity is very high.
Took forever to make that connection.
Are you sure you don't have an RF source somewhere in your body? ::)
« Last Edit: November 06, 2018, 07:24:14 pm by Dave Garoutte »
Jonathan Johnson
« Reply #11 on: November 06, 2018, 04:06:20 pm »
Is it your pacemaker?
("Every time I hear that noise, my heart skips a beat!")
Lyle Williams
« Reply #12 on: November 07, 2018, 02:21:33 pm »
A good bet for buzz in a home audio system is an unbalanced lead with inadequate conductor diameter.
lindsay Dean
« Reply #13 on: November 07, 2018, 02:24:51 pm »
Is this a semi-pro recording setup or do you have power strips thrown throughout the area and expecting it to stay clean?
     and Pray for higher guidance
Jean-Pierre Coetzee
  • Gauteng, South Africa
« Reply #14 on: November 10, 2018, 02:03:46 am »
Let's just bypass the power grid completely. Have you considered running on generator or installing a double inversion ups to test?
With the UPS it could still be grounding related but I doubt that.
Pull every single interconnect cable and make sure it is a balanced cable going into a balanced connector (and out of a balanced connector). Also have some of the gear serviced, maybe a cap or 50 are leaking in your rig?
Audio Technician
Word & Life Church
- Ivan Beaver
Page created in 0.05 seconds with 25 queries.
