Author Topic: Neutric Powercon Question  (Read 5977 times)
Kemper Watson
« on: October 31, 2018, 06:39:02 pm »
In using the standard Powercon connector the manufacturer states that it shouldn't be unplugged under a load. My question is if the device is off is it under a load? In other words do I need to unplug the male end first.. I just purchased a few powered wedges...
Thanks for your time...
Re: Neutric Powercon Question
« Reply #1 on: October 31, 2018, 07:22:53 pm »
Maybe.  Most things digital have some amount of parasitic load, our iTechs (4 to a rack) draw enough when powered down at the front panel that an L21-30 will spark at the rack pack inlet if the cable is already powered.
Jean-Pierre Coetzee
  • Gauteng, South Africa
« Reply #2 on: November 02, 2018, 06:53:29 am »
Now for an alternative question, what is the difference between the original Powercon and the True1 units now. I can imagine the rule is there to prevent arc flashes but seeing how deep the Powercon connector is, is it really that serious for low current loads?
Audio Technician
Word & Life Church
- Ivan Beaver
Taylor Hall
« Reply #3 on: November 02, 2018, 11:01:17 am »
The True1 connectors are IP65 rated and utilize a completely different locking assembly to keep them separate from the "plain" powercon connectors. They are also able to be hot-swapped under load as they have breaking capacity baked in. Those are the only differences. Well, that and not being able to utilize the same gauge wire/jacket thickness cable that standard powercons can (yet, supposedly they're working on this).
1) Do it right
Jonathan Johnson
« Reply #4 on: November 02, 2018, 04:01:51 pm »
To clarify, this means that the contacts can handle the inevitable arcing that occurs when making/breaking the connection under load.
The contacts in the original Powercon connectors can be damaged by such arcing.
dave briar
  • Helena Montana
« Reply #5 on: December 22, 2018, 03:46:36 pm »
To whit, our FBT StageMaxx monitors don’t even have off/on switches — the True1 connectors perform that function.
..db
Lyle Williams
« Reply #6 on: December 23, 2018, 01:29:31 am »
Better to think of them as being unsuitable for repeated connection/disconnection under FULL load.
Phillip Ivan Pietruschka
« Reply #7 on: December 27, 2018, 07:01:43 pm »
Indeed. I couldn’t count how many Meyer’s I’ve connected or disconnected with an idle load without issue.
Dan Mortensen
« Reply #8 on: December 27, 2018, 07:32:35 pm »
With all due respect, this will be true for a while and then it won't be true at all as the connector will have damage from repeated small sparking.
My shop stereo was four UPM-1P's for a few years and I used a Powercon barrel to turn the agglomeration on and off, no music playing at turn-on/turn-off.
After a couple years that barrel and the Powercon->Edison stopped working.
True, it was four and not one but the principle is the same IMO. Small load can wreck Powercon when twisted while on.
One person's anecdote FWIW.
Steve Litscher
    • 608 Sound and Light
« Reply #9 on: December 28, 2018, 11:42:07 am »
So... any idea why several manufacturers choose to ignore the Neutrik direction by not including a power switch for their PowerCon-configured devices?
We have a bunch of TTL-6a speakers from RCF - none have a power switch, and all have PowerCon in/out receptacles. I'd think that engineering powerhouses like Meyer, RCF, etc would know better?
Page created in 0.057 seconds with 22 queries.
