Author Topic: X live issue  (Read 2889 times)
Luis_Marquez
X live issue
« on: October 30, 2018, 01:11:47 pm »
So my x live card is not happy. It was working properly when first installed. Then sessions list on iPad went blank.On the x32rack, it would show as a madi card. Originally installed A11 . Now has A12 on 3.09 firmware. Been ok but now no session list on both iPad and rack. When trying to record, it does not respond. Playback is good. I re seated the card and disc. No luck. Routing seems ok. Recorder not responding.
Kevin Bayersdorfer
Re: X live issue
« Reply #1 on: October 30, 2018, 08:13:35 pm »
I had an SD card go bad and it showed as MADI
Aaron Maurer
Re: X live issue
« Reply #2 on: October 30, 2018, 08:16:34 pm »
I will echo that my Xlive is not working properly either.  Can only record for about 5 seconds and a message comes up “finalise session”. Cannot play back anything. Running 3.08.
Robert Lofgren
Re: X live issue
« Reply #3 on: October 31, 2018, 07:36:54 am »
Try to format the sdcard on the x32. If you try to delete files using the normal computer delete function the the files may still be allocated causing fragmentation that will severely impact the sdcard performance.
Also, make sure that if you format the sdcard outside of the x32 that the blocksize isn’t too small. 32k is a good blocksize. You should also not use any quick-format but instead perform a full format.
Terry Martin
Re: X live issue
« Reply #4 on: November 08, 2018, 11:11:25 am »
I haven’t had these issues yet.  I’m using a 64GB card in mine formatted from a PC.
Re: X live issue
Page created in 0.03 seconds with 24 queries.
