Author Topic: Chauvet Hurricane haze 2d fan blows, no output.  (Read 1593 times)
Dave Guilford
« on: October 12, 2018, 01:10:10 am »
Everything seems great except no output.  Best way to clean?  Will vinegar / cleaning solution work if liquid isnít moving through the system?
Easiest way to clean?
Dave Garoutte
  • San Rafael, CA
Re: Chauvet Hurricane haze 2d fan blows, no output.
« Reply #1 on: October 12, 2018, 11:30:09 am »
Gunk solidifies in the little smoke tube.
I sometimes take a very small wire strand and poke my way back down the tube.
Or compressed air.
Inventor.
Dave Guilford
« Reply #2 on: October 12, 2018, 12:17:54 pm »
Or compressed air.
The flexible plastic intake tube? Or the little metal one where the haze outputs?
Dave Garoutte
  • San Rafael, CA
« Reply #3 on: October 12, 2018, 01:15:42 pm »
The little metal one.  It has a very small through hole which doesn't take much to clog.
The plastic pickup tube should have a filter on it to keep any particles out.
Inventor.
Daniel Levi
« Reply #4 on: October 12, 2018, 04:48:38 pm »
Bigclive just did a video on this, https://www.youtube.com/watch?v=Yz5MP76EuZc .
Not watched it fully but knowing his experience he should know what he is doing.
Dave Guilford
« Reply #5 on: October 17, 2018, 03:48:51 pm »
OK Iím currently disassembling this.
After using a high quality pipe cleaner in the exterior metal output tube, I can feel air coming out of it when itís supposed to be spitting out haze. So nothing seems clogged there.
That said- it seems like all the tubes arenít empty. Perhaps itís the pump after all.  It doesnít seem serviceable though.
David Allred
« Reply #6 on: October 17, 2018, 03:54:00 pm »
Disconnect the tube from the output side of the pump and press the manual button.  Does it pump fluid?
Len Zenith Jr
« Reply #7 on: October 17, 2018, 04:00:37 pm »
Take the output tube off the pump and see if it is pumping fluid. They can burn out pretty quick if you run them dry, otherwise they are usually pretty solid. New pumps are pretty cheap, they sell them for about $30 linky. If you need something quick and cheaper, these are the same pumps used in commercial coffee machines. Your local business wholesaler would have a box of them laying around although  pump output volume does vary from model # to model #.
¬ę Reply #7 on: October 17, 2018, 04:00:37 pm ¬Ľ
Page created in 0.034 seconds with 22 queries.
