Pages: 1 ... 23 24 [25]   Go Down
Author Topic: New Midas console?  (Read 67353 times)
Brian Hancock
Re: New Midas console?
« Reply #240 on: May 06, 2021, 10:12:54 am »
https://forums.prosoundweb.com/index.php/topic,168821.0.html check this thread from a while back the 9620 and larger sibling work same way as far as the optical transmission goes ... rack it put I'm an st patch with sm bidi sfp and an lc to st jumper and away you go ... st is basically standard field tatical fiber ... you can buy it cheaply, repair easy and subrent abundantly ... as as mentioned before its really standard in buildings nowadays that are fairly modern plenty of arenas etc. Work great just used this on a show this week with a pro 2 fyi.
keven mcdonald
« Reply #242 on: May 08, 2021, 04:12:47 pm »
Optocore is definitely not MM only... we use Broaman video products (parent/sister company of optocore) along with digico consoles to pass a whole bunch of stuff with CWDM using a mux22 unit, and do it all using singlemode expanded beam HMA connectors. In fact, you can spec digicos with these connectors from the factory.
Andrew Broughton
    • Check Check One Two
-Andy
Russell Ault
  • Edmonton, AB
« Reply #244 on: May 09, 2021, 05:50:33 pm »
Good to know! That must be a recent(-ish) change; this Optocore cabling document (which, admittedly, is dated from 2008) only talks about MM.
-Russ
Pages: 1 ... 23 24 [25]   Go Up
Page created in 0.039 seconds with 22 queries.
