Pages: 1 2 [3]  All   Go Down
Author Topic: Electrocution in OKC  (Read 2775 times)
David Allred
Re: Electrocution in OKC
« Reply #20 on: October 05, 2018, 07:24:22 am »
And even if the judge allows it to continue, municipalities are often protected by strict and laughable award limits even if proven grossly negligent.  In my Tennessee case our county was only exposed for $100K regardless of any legal finding.  This is the kind of thing that causes lawyers to shriek in terror and run away from a case before the first motion is filed because 33% of peanuts is 1/3 of said worthless legumes and they know it.  As it was designed to do.
Sent from my mobile phone using Tapatalk
I was saying that the city might sue the individual that broke  their light, causing the whole mess.
David Buckley
« Reply #21 on: October 16, 2018, 06:08:18 pm »
If the lighting bollards along the canal are owned by the "public" (I don't know what the right term is in American, here it would be Council owned) then they may well not fall under the NEC but under the NESC, which does not (to this day) require that public space lighting is grounded in the same way that it would be if the NEC applied.
How to do shock prevention from public space lighting (a/k/a/ street lights) with metal poles is a conundrum worldwide, as there are a number of conflicting issues, the biggest of which is "what exactly is ground?"
In a conventional (US) electrical installation, the neutral and ground are bonded in the service entrance, and that ground is then distributed throughout the premise to form an equipotential zone.  This can sort of be done in streetlights too; there is a neutral/ground bond and earth rod at each streetlight, with the note that sometimes the steel pole is itself the ground rod, so the neutral is effectively connected to the pole.  There is no ground conductor to or between streetlights.
Another permitted approach is that there is no electrical connection at all between the pole and wiring.
The problem with these approaches is that under fault conditions the pole can become live, and that is bad, and as noted in this article, it ended up being fatal.   But that is perhaps less surprising, because the bollard light was dragged into the canal, and so it is possible that one or more of the wires were strained and removed from their terminations, which could cause a fault and shock situation even with no underlying fault or contributions from the design.
The only approach I think works reasonably well (but only over a short distance) is to wire the poles to the full NEC, so a ground conductor is also run to each pole.  This is the way its done in private spaces for their outdoor lights.
Dave Garoutte
  • San Rafael, CA
« Reply #22 on: October 16, 2018, 07:01:26 pm »
It seems like the only thing that truly could have prevented these deaths would be a GFCI circuit.
Even with a wired ground, if the pole broke off the base and got energized, anything touching the metal would get juiced.
Inventor.
Pages: 1 2 [3]  All   Go Up
