Author Topic: Good Value HDMI to SDI (And SDI to HDMI) Video Converter  (Read 2431 times)
Ray Aberle
    • Kelcema Audio
Re: Good Value HDMI to SDI (And SDI to HDMI) Video Converter
« Reply #10 on: August 17, 2018, 02:35:07 pm »
Thanks all for the great input thus far!  I am definitely more of a buy once, cry once type guy, though I take value into large consideration.  So it sounds like with that in mind, the Decimator MD-LX may be the way to go.
With that said, I was looking at a BMD that could take 1 HDMI input and output it to up to 2 SDI outputs: BMD Micro Converter HDMI to SDI (longb&hlink)
This is so that I can take 1 HDMI output from a computer, and use the 2 SDI outputs to run to the screen on each side from the same box.   It didn't seem like the MD-LX could do that?  Is there another affordable Decimator product that could do this, or is there another good way to do this affordably but also reliably?
You are right in that the Micro Converter will output to two SDI things at once... but to be candid, be redundant. Get an SDI D/A (BMD has a 1x8 that's pretty affordable) to keep on hand as well. Otherwise, what happens when one output fails...
-Ray "raging levels of paranoia" Aberle
Kelcema Audio
Taylor Hall
« Reply #11 on: August 17, 2018, 04:56:17 pm »
We use the Decimator MD-HX. Rock solid performance and the ability to manage them via USB is nice too. Sure it's more expensive than the BM micro or the MD-LX, but it's damn near a swiss army knife as far as converting and scaling is concerned.
You can convert HDMI and SDI in any combo you like, and will also split the output up to 4 ways. They handle audio as well, though you start to get limited slightly in routing.
1) Do it right
brian maddox
  • HeyYahWon! ttsss! ttsss!
« Reply #12 on: August 17, 2018, 04:57:19 pm »
Everyone else's comments are well considered, so i won't add much other than that i've used the BMD stuff a LOT and overall the reliability has been pretty good.  The Decimator line is better though, in most ways for most of their products.
I've also had reasonable success with the ultra cheap off brand SDI-HDMI converters that you can find on amazon and elsewhere.  They can often be had for 20-30 bucks.  Good for using consumer monitors at the end of a SDI run.
Remember to pay attention to how many "G's" the converter will handle.  Some can do up to 4K and will handle nearly anything you throw at them.  Other's top out at 720p.  Just an inconvenient gotcha to look out for.
brian maddox
bdmaudio@gmail.com
Joris Jans2
    • Vester Theater Techniek
« Reply #13 on: August 18, 2018, 05:17:30 am »
With that said, I was looking at a BMD that could take 1 HDMI input and output it to up to 2 SDI outputs: BMD Micro Converter HDMI to SDI (https://www.bhphotovideo.com/c/product/1247783-REG/blackmagic_design_convcmic_hs_micro_converter_hdmi_to.html?sts=pi)
use a couple of these in some media server applications & they have been flawless for me. heard some issues with the mini-converter (previous, bigger generation with audio) but the micro converter is perfect for what i do (touring theater show)
Erik Jerde
« Reply #14 on: August 18, 2018, 09:02:38 am »
Decimator MD-HX.  Itís got HDMI in/out, sdi in and 4x sdi out grouped in pairs.  It also has an up/down/cross converter built in.
If youíre doing 1080p or higher you get into a more complicated realm of SDI where thereís type A and type B.  Decimator does both.  BMD just does type B.  Itís not a big deal if you stick with everything from the same company but thatís hard to count on.
brian maddox
« Reply #15 on: August 18, 2018, 12:40:56 pm »
This^^
The A and B thing can get pretty infuriating when you're mixing and matching various manufacturer's products, so that's another interesting gotcha.
brian maddox
bdmaudio@gmail.com
Joris Jans2
« Reply #16 on: August 30, 2018, 04:41:16 pm »
BMD micro converter does A & B, but only switchable with PC software...
¬ę Reply #16 on: August 30, 2018, 04:41:16 pm ¬Ľ
Page created in 0.055 seconds with 24 queries.
