Author Topic: Mackie ProFX16 Spitting Noise Issue with Effects  (Read 284 times)
Teagan Draw
« on: July 19, 2018, 11:06:05 am »
We purchased an entire new PA system a couple years ago. We are running 2 powered speakers (2 mains, 2 monitors) w subs from a Mackie ProFX16. The system sounds incredibly and works perfectly EXCEPT when using the effects on the Mackie ProFX16. If we put any sort of effect on it will randomly start making a spitting hiss nose every 2-3 seconds or so and will not stop once it starts. Sometimes we can get a set in before the noise starts, other times it happens right at sound check. It is very frustrating to have to run the effects dry but it is the only way to stop the noise. Once the effects are turned down we do not hear it. It is not a constant noise, just sounds like a hiss/spit every 2-3 seconds. We tried calling Mackie and they could not help. Getting ready to get rid of this board if we canít fix it.
Brandon Scopel
Re: Mackie ProFX16 Spitting Noise Issue with Effects
« Reply #1 on: July 19, 2018, 11:12:50 am »
Welcome, before anyone can answer your question, you'll need to change your display name to your REAL FULL first and last name.....This thread WILL get locked if not.
¬ę Reply #1 on: July 19, 2018, 11:12:50 am ¬Ľ
Page created in 0.061 seconds with 22 queries.
