Author Topic: Porta Church System  (Read 2496 times)
Fred Dorado
Porta Church System
« on: June 20, 2018, 06:44:32 pm »
We may be moving our services to a school near us. We are experiencing some growth and are thinking about holding services at a school across the street. Our building is fairly small and we did this for Easter and it worked out great.
We rented a system, which was great for a one time, but if we do this regularly, we would want our own and something faster and easier to setup.
Pictures of our Easter service below. That was about 250 people - right now we are about 140 between 2 services and would do 1 service for now. That event went well with ETX 15p mains and 4 PRX712 monitors. Had stage volume issues and would have like more low end and will most likely be using electric drums in future. We had a QU16 and AB168
We don't have a budget, which is what I am trying to figure out, but I am thinking about 8-10k, but that will also need to include a laptop and some misc like portable mic stands
Here is what I am thinking, might be an easy setup.
There is glass right behind the musicians so stage volume is an issue and not sure we are ready for in ears yet.
Allen and Heath SQ5 & DBX168 - DBX in rolling case placed near band
2 x Electrovoice - Evolve 50's for mains
5 x ????? for monitors - stage volume is an issue, I was thinking something small like a Mackie SRM150, but the extra outlets and the extra cables might be an issue. amps on the rack with the DB168 would simplify connections and single speaker cables would clean up a little.
So my questions
1. Would the 2 Evolve's be good for mains - flat floor, wide and not too deep room.
2. What would be a good monitor option?
thanks
Dave Pluke
    • BIGG GRIN Productions
Re: Porta Church System
« Reply #1 on: June 20, 2018, 09:51:40 pm »
Are you referring to a dbx compressor?  I can't imagine it would be necessary, given the SQ5 (as do other digital consoles) will have compression built-in.
So my questions
I can't speak to the Evolves, but think you're on the right track with the speaker format (considering your room).  Make sure to demo before you purchase to make sure the system will be loud enough.
As to monitors, 5 wedges in that space would be a nightmare (and I LOVE wedges).  Something on the order of hotspots might be easier to control.  Or, try one wedge for the drummer and a (small) speaker on a stick on each side of the band.
But, before you leap, consider the ME 500 personal monitors.  I worked in a Church with a Midas M32 and Behringer P16 personal monitors and it sure made mixing easier.  Either system allows each musician to dial in their own mix.  I think you'd be pleasantly surprised at the acceptance rate.
Dave
« Reply #2 on: June 21, 2018, 01:07:07 am »
Yes why the DBX and why the A&H that has poor tablet support.  Maybe next year but can't recommend it now.
The M32r will be familiar  to anyone with an x32 pedigree.
I dont anything about the EV's.
The concept of fitting a system to a budget is frought with compromises.  A professional advisor will have you set goals tjen design a system to meet thise goals.  Then you go and find the money.
Sent from my VS996 using Tapatalk
TJ (Tom) Cornish
  • St. Paul, MN
« Reply #3 on: June 21, 2018, 06:21:08 am »
Fred, this is the perfect situation for in-ear monitors - no wedges to lug, significantly less stage volume.  The Sennheiser EW IEM G4 systems come in a two-receiver per transmitter option which puts the cost at around $600 per person plus in-ear buds.  To step into this, you could get a system or two for the folks that move around, and go wired for the back line if youíre willing to deal with the wires.  Behringer P1 units will plug directly into your stage box outputs and provide a headphone jack and volume control in a pack that can be worn on a belt and either be powered by 9v batteries or AC adapters.
There are lots of permutations that can work depending on budget, but after having done portable church a couple times over the years, I will suggest that money spent on logistics - in-ears instead of wedges, a rack instead of a pile of small items, self-powered speakers instead of amps+speakers, etc. is going to make you a lot more popular to the team that has to lug all the junk every week, even if that is at some significant cost.
Itís been a couple years since I updated it, but I put together an example portable system that you may find helpful.
TJ (Tom) Cornish
  • St. Paul, MN
« Reply #4 on: June 21, 2018, 06:23:58 am »
He means the A&H stagebox: https://www.allen-heath.com/remote-audio-sq/
TJ (Tom) Cornish
  • St. Paul, MN
« Reply #5 on: June 21, 2018, 06:27:38 am »
The SQ series is significantly more mixer than the X32/M32 which are starting to get long in the tooth.  Iím not up on the limitations of the tablet software for the SQ series, but unless thatís a deal-breaker, the SQ series is better in many ways.
Iíve used the GLDs since they came out in 2012 and A&Hís tablet app for the GLD is very decent, so whatever limitations there may be at the moment will be solved eventually.
Fred Dorado
« Reply #6 on: June 21, 2018, 02:17:26 pm »
A couple things -
I an thinking SQ5 because I really liked the GLD80 I put in my old church, and thought SQ5 would be similar and an upgrade from the QU series - Yes the A&H DBX168 stagebox
TJ - thanks for the link, I will read through it.
You are right, in ears would be easiest, but apparently they tried previously in the main building without success, and I am worried about the history, making the move etc and trying to make it as easy as possible on musicians.
the band is very different now and our worship leader has used them before, so it is a possibility.
I also saw Bose has some new small monitors that can run on battery or plug in. This might be an option.
As Dave said, floor wedges may be a bit much. We had 4 before and did ok, thinking more we have, less we have to have in each one and lower overall volume.
Dave Pluke
« Reply #7 on: June 21, 2018, 02:34:03 pm »
That makes a LOT more sense - thanks, TJ!
Dave
TJ (Tom) Cornish
  • St. Paul, MN
« Reply #8 on: June 21, 2018, 02:58:45 pm »
A couple things -
One way of addressing in-ear-itis is to schedule a long tech rehearsal day to work through in-ear issues.  There's no doubt that it's an adjustment, but IMO now is a great time to try to tackle this, since you have other changes going on, and you can make the case for why they would be helpful now - less gear to lug, greatly reduced stage volume in the new room, etc.
Coaching them on how to communicate what they need may help a lot, too, as well as soloing their mixes to see what's going on.  I've found that even learning what to ask for in the in-ear mix is a skill that has to be learned.  Make sure people have musician-style isolating buds and not the typical iPhone-style buds.  That makes all the difference.
Younger folks will likely be more open to this than older folks.  Good luck - it really is worth it from many angles.
Mike Caldwell
  • Covington, Ohio
« Reply #9 on: June 21, 2018, 05:57:54 pm »
Allen Heath has the ME series personal monitor system that integrates with the QU an the SQ series.
With your proposed total set up I can't see what you would gain...or really need that could not be done on the QU series and at least at this time the iPad app is better for the QU.
Get a QU pac and a AB168 if you need more than 16 channels and run it remotely Via Ipad and not even set up a FOH. Everything could be racked up and as plug and play as possible.
I would also invest in some pipe and drape to put up in front of the windows if that's where your are
always going to set, it will help the sound and everyone in the congregation will not be looking into the bright sun shining in the windows.
¬ę Reply #9 on: June 21, 2018, 05:57:54 pm ¬Ľ
Page created in 0.052 seconds with 22 queries.
