Author Topic: Best way to do a transfer function of an amplifier output?  (Read 3174 times)
Art Welter
Re: Best way to do a transfer function of an amplifier output?
« Reply #10 on: October 23, 2018, 06:18:15 pm »
Next time I'll probably just get some oil-filled electric radiators and put a few in parallel.
Chris,
Since I already had them, used to do that, but it took 5 heaters to do a 2 ohm load, since those 1500 watt 120V heaters were about 9.6 ohms. Dragging 5 heaters to the shop was too much work, and could only test one side at two ohms.
Then I found that wrapping baling wire around a brick worked quite well, and is even cheaper than Mark W's solution, but does have some heat safety issues  ;)
IIRC, using a  8"x 3" x 2.25" brick and 16 gauge steel baling wire at about 1/4" spacing came out to 4 ohms.
Art
Mark Wilkinson
« Reply #11 on: October 23, 2018, 08:02:04 pm »
Art
 ;D
Did peeing on the bricks increase thermal capacity ? Lol
Art Welter
« Reply #12 on: October 24, 2018, 01:12:58 am »
;D
Yes, but changes the impedance too much for repeatable and reliable measurements.
Stinks like hell, too.
Frank Koenig
« Reply #13 on: October 24, 2018, 11:50:22 am »
I've mentioned this trick before but this sounds like a good place to mention it again. You can arrange the load resistor as a voltage divider so that you can hook a speaker to the tap and hear, at a pleasant level, what the amp sounds like when it's killing itself. Since the attenuation is high the source resistance seen by the speaker is low, and all is hunky-dory. -F
Page created in 0.048 seconds with 24 queries.
