Pages: 1 2 [3]   Go Down
Author Topic: How to keep tops from rotating  (Read 3177 times)
Roch Lafleur
  • Ottawa, ONTARIO
Re: How to keep tops from rotating
« Reply #20 on: June 13, 2018, 11:46:54 am »
Another happy SM80/BT-12/K&M crank distance rods here. I had the same problem when I first got the SM80s. They would spin around sending sound either away from the front of the stage or towards the stage, sometimes creating feedback. I used gaff tape to hold them in position, then ratchet straps. My life has been much easier since the BT-12s arrived. I use them even if I don't need to tilt the speakers to prevent the spinning. They are also amazingly built tilters. They weren't cheap once I paid for shipping, duty, taxes and converted to Cdn$, but totally worth it.
DSL SM80 (2), DSL TH118 (4), db Technologies DVX DM-12, JBL PRX615M, Behringer X32, X32-C, Crown MAi, QSC PLX
Debbie Dunkley
  • Central North Carolina
« Reply #21 on: June 13, 2018, 02:28:49 pm »
 :D    Mine still win the lowest cost option....
Riley Casey
« Reply #22 on: June 13, 2018, 02:50:50 pm »
Take out what ever plastic cap fills the end of the stand tube so that the speaker socket rests on the aluminum tube end. See Gordian Knot.
Gilbert Medina
« Reply #23 on: June 15, 2018, 02:16:01 am »
I use a method I have been doing for years - cost?... zero.
I take old plastic containers - like those that contain vinegar, oil, sauce etc and when  it is empty, I cut small pieces out of them about 3" by 1" and round off the edges to make small shims.  I get dozens from one container.
Because the container is already curved, the shape of the shims is perfect.  I take them to shows in a  baggie and once the speakers are positioned, I slot them up into the top hat positioning them at the back so they cannot be seen - usually 2 is enough. Takes a second and costs nothing. If I don't end up getting them back - oh well I gots me plenty more.......
That is a great idea Debbie, I am going to try this on my 815's...
Sent from my Pixel 2 XL using Tapatalk
Douglas R. Allen
« Reply #24 on: June 15, 2018, 09:34:19 am »
After 2 gigs, I am super happy with these Danley SM80s.  I am getting even, articulate sound at a reasonable volume, using relatively little power.
However, with occasional wind gusts, I am experiencing a "sail" effect, which rotates the speaker in the K&M crank stand.  I used a temp fix with gaff tape, but I'd like to see if anyone is using a more elegant solution.  Some thoughts include a grooved plastic piece on the top of the pole, or something more drastic to keep it from rotating.
Thanks!
I just crack a few Solo cups up and slide 1 or 2 pieces up in the back between pole and top. Easy to size as needed. They seem to be everywhere........   ;-)
Douglas R. Allen
Debbie Dunkley
« Reply #25 on: June 15, 2018, 09:44:25 am »
U R welcome...with all the costs associated with accessories in this business - let alone the equipment itself - you gotta love something thats free but actually works!
Pages: 1 2 [3]   Go Up
Page created in 0.047 seconds with 23 queries.
