Author Topic: Mackie 1604 VLZ Post Mute and Post Eq  (Read 1354 times)
Aaron McQueen
« on: December 13, 2005, 10:55:45 am »
I have a Mackie CR1604 VLZ (not PRO version) where Aux 1 and 2 (used for monitors) are pre mute and pre eq (this seems pretty usless to me, when I press mute, I'd like the channel to mute, not just in the mains).  I can make the mute work if use post fader but then I loose seperate control of the monitor mix.  I found on the Mackie website a way to modify to board to make it post eq, but there is no post mute mod.
http://www.mackie.com/pdf/compactmixer_mods.pdf
Has anyone done the post eq mod, and does anyone have any information on the post mute mod?  I'm an electronics technician by trade so I shouldn't have problems soldering or cutting traces.
We are getting a new board soon, so this one will be used for remote events, or maybe the youth.
Thanks in advance.
Faith comes by hearing, and hearing by the word of God - Romans 10:17 NKJV
Ron Riedel
Re: Mackie 1604 VLZ Post Mute and Post Eq
« Reply #1 on: December 13, 2005, 11:06:34 am »
The SR32-4 comes from the factory with the same poor choice of mute/eq routing. I was able to modify both the mute and eq so that all AUX's would be post eq/mute, but it's been about 5 years, so I don't remember a lot about it. I know Mackie provided some info, but it seems like I had to invent part of the mod on my own. I'll dig around and see if I can turn up any documentation.
I would guess if it's possible on an SR32, it would be possible on the 1604. I think the channel circuitry is pretty similar on the two boards.
Ron
Jason Ellis
« Reply #2 on: December 13, 2005, 02:46:04 pm »
If I remeber correctly I've got that the mod on disc in PDF format...I'll try to forward it to you tonight...PM me to remind me if you don't mind...
David Sheneman
    • http://www.rfa.cc
« Reply #3 on: December 14, 2005, 10:28:16 am »
Please share your findings here as I can use the same information and I'm sure there are others in the same boat.
David Sheneman
Director of Sound & Lighting
Rockford First Assembly
Rockford, IL
daves@rfa.cc
(no smoke signals or semaphore please)
Aaron McQueen
« Reply #4 on: December 14, 2005, 10:51:22 am »
Jason sent me the service manual, so I can trace out the right path.  Once I make the mod I will post some pictures, but it may be a while because currently it is in service, so I have to wait for the new board before I do anything.  We are replacing this with a Yamaha MG32/FX.
Aaron McQueen
« Reply #5 on: December 15, 2005, 08:37:45 am »
This board must go, one of the faders starting acting up last night. Crying or Very Sad
Page created in 0.078 seconds with 21 queries.
