Author Topic: Behringer X32 output question  (Read 2897 times)
Jim Rapier
« on: May 11, 2018, 07:37:52 pm »
I have a Behringer X32 that we use for live audio on Sundays. I have no issues with the live audio, the issue I am running into is my recordings. I am using xlr out 3 to send Audio to a dvd recorder and the usb recorder for just audio. The issue I have is that the audio is way low on both recordings. Is there a way to increase volume on these two outputs without altering my live output?
Re: Behringer X32 output question
« Reply #1 on: May 11, 2018, 08:15:58 pm »
What mix do you have feeding xlr3?  That's the key question.
The outputs can be connected to matrix and mixbus
Sent from my VS995 using Tapatalk
River Delta Audio is now:
Luke Geis
« Reply #2 on: May 11, 2018, 10:41:45 pm »
I agree that utilizing a Matrix is probably the easiest answer.
Joe Pieternella
« Reply #3 on: May 12, 2018, 08:43:54 pm »
Mixing at and around unity gain will give relatively weak digital signals. Unity gain is -17dBFS which to be honest is low but not necessarily "way low".
Are those very weak signals apparent in both the recording and on the recorder.
How are you connecting the recorder ie what kind of connector is there on the recorder. If xlr cables are being used could it be that one leg of the cable is broken.
Does the recorder maybe have an input sensitivity knob or menu function.
Where do your board meters usually peak. If the system is very "sensitive"/ to powerful for the space it's in you'll be sending little signal through the mixer automatically giving you low recording levels.
Are you maybe sending the monitor out to xlr output 3.
Do you maybe inadvertently have a DCA assigned (don't ask how I know)
Verstuurd vanaf mijn G8341 met Tapatalk
« Last Edit: May 12, 2018, 08:47:28 pm by Joe Pieternella »
Jim Rapier
« Reply #4 on: May 18, 2018, 07:16:17 am »
I am feeding everything with the LRC output. After reading all of these replies it is very apparent that I am in over my head. I am going to have to hire a pro, I appreciate all of the responses.
Kevin Maxwell
« Reply #5 on: May 18, 2018, 04:26:19 pm »
Over on the Behringer X32 forum you can upload your scene and people are willing to look at it and see if there is anything obvious. I am one of those people.
https://forum.musictri.be/forumdisplay.php?118-X32-Family
David Winners
  • Bryan, OH
« Reply #6 on: May 25, 2018, 06:38:00 am »
Setting up a matrix out for your DVD recorder would be best. Then you would have control of the level sent to the recorder without changing your LCR levels.
You can send me your scene and I can set it up for you. My e-mail is my first name dot my last name @ gmail dot com.
Jim Rapier
« Reply #7 on: June 13, 2018, 08:08:04 am »
Awesome, thanks for the info. Is there a particular forum over there that I would upload the scene to?
Kevin Maxwell
« Reply #8 on: June 13, 2018, 10:20:05 am »
This one pick which Sub forum you think is best.
Page created in 0.115 seconds with 24 queries.
