Author Topic: WWB Scan differences between products  (Read 1715 times)
Andrew Broughton
    • Check Check One Two
« on: April 10, 2018, 03:56:55 pm »
I have some PSM1000 and UR4D and was using both to scan as the UR4D is in a higher range than the PSM1000.
However, the scan that the UR4D is producing in WWB has a "floor" that's about 20db higher than the PSM1000, and in the overlap area, the scan is not the same. Now the difference in the scan could have to do with the location of the 2 devices being in a different location when I scanned that day, but this "floor" of 20db seems very strange. Both receivers in the UR4D produce scans that look the same, with that same raised "floor" and higher/different readings than the PSM.
Any idea what's going on here? (The PSM is the lower trace)
« Last Edit: April 10, 2018, 03:59:36 pm by Andrew Broughton »
-Andy
Jordan Wolf
Re: WWB Scan differences between products
« Reply #1 on: April 10, 2018, 04:13:06 pm »
Yeah, anytime I scan with UHF-Rs, the noise floor baselines at -100.
ULX-D, QLX-D show up as your PSM1000 does - lower and with better resolution, IMO.
Jordan Wolf
Andrew Broughton
« Reply #2 on: April 10, 2018, 04:48:17 pm »
Ok, thanks!
-Andy
Russell Ault
  • Edmonton, AB
« Reply #3 on: April 11, 2018, 06:10:01 am »
Not speaking to the noise floor, but ~30dB extra signal being received by your UR4Ds seems like a lot of extra signal to me. What antennas/distro are you using with the UR4Ds, and was the PSM near one of your RX antennas when you did its scan?
-Russ
Jason Glass
    • CleanWirelessAudio.com
« Reply #4 on: April 11, 2018, 05:43:13 pm »
Edit: I totally misunderstood your post.
« Last Edit: April 11, 2018, 05:47:23 pm by Jason Glass »
Andrew Broughton
« Reply #5 on: April 11, 2018, 06:07:45 pm »
Here's a scan with the 2 receivers in the same place. The PSM1000 has it's normal wire antennas, the UR4D has the 1'-ish whips that they come with, no distro for the UR4D as I only have the 1 unit.
The scans match in some places but in others the UR4D has a higher reading, like the 1st bump around 521Mhz... Any thoughts as to what's going on there?
« Last Edit: April 11, 2018, 06:09:53 pm by Andrew Broughton »
-Andy
Pete Erskine
    • Best Audio
« Reply #6 on: April 11, 2018, 06:43:06 pm »
The PSM1000 has less sensitivity than the mic RX.  Artificially the noise floor is a straight line and not a real measurement.  That they essentially match in the peaks shows that they are doing the same scan.
Pete Erskine
917-750-1134
www.bestaudio.com
peter@bestaudio.com
Andrew Broughton
« Reply #7 on: April 11, 2018, 09:07:27 pm »
Thanks, Pete.
Except where they don't. What do you make of that?
-Andy
Pete Erskine
    • Best Audio
« Reply #8 on: April 12, 2018, 10:15:18 am »
Thanks, Pete.
no two scanners from different manu will ever totally match  all that is important is seeing where the dtv is, not the actual detail.  zoom in to 1 mhz wide to see a freqs detail.
Pete Erskine
917-750-1134
www.bestaudio.com
peter@bestaudio.com
Jordan Wolf
« Reply #9 on: April 12, 2018, 10:39:35 am »
Pete,
Both devices are from Shure; one is a UHF-R receiver and one is a PSM1000 receiver.
I guess their RF stages are tuned for somewhat different end uses?
The variation between scans shows +/-10 around the start freq. of TV23.
Im curious as well - is this amount of difference typical?
Jordan Wolf
Page created in 0.032 seconds with 19 queries.
