Pages: [1] 2 3  All   Go Down
Author Topic: No fuses? No problem!  (Read 8640 times)
Nathan Riddle
  • Niceville, FL
    • Nailed Productions
« on: March 30, 2018, 10:42:35 AM »
John Daniluk (JD)
Re: No fuses? No problem!
« Reply #1 on: March 30, 2018, 11:25:23 AM »
While running a power issue in a club, found bolts replacing the 100a fuses....
jd
« Reply #2 on: March 30, 2018, 11:59:46 AM »
Back in the '70s I was repairing a custom fixture and found a length of aluminum round stock cut to length and used in place of a standard fuse. I charged an extra "stupidity tax" for that repair.
Keith Broughton
  • Toronto
« Reply #3 on: March 30, 2018, 05:40:59 PM »
ECM always has an interesting article or two. This one's a doozy :)
http://www.ecmweb.com/ops-maintenance/12-reasons-why-electricians-should-always-be-looking-trouble/gallery?slide=11
I suspect under heavy load or a short, those copper wires would vaporize :o
Mike Sokol
« Reply #4 on: March 30, 2018, 07:24:03 PM »
Yes, we call that a fuseable link... ;)
Stephen Swaffer
« Reply #5 on: March 30, 2018, 07:57:34 PM »
I have seen 1/2" copper pipe flattened on each end to fit in place of a 100 amp size fuse.  Seems like more work thatn it is worth.
That said, there is a situation where a non-fused disconnect would be acceptable-if the upstream over current protective device is sized appropriately, sometimes code requires a disconnect "within sight" of a load.  If that is the case here, the only real code violation is the fact that those fuse holders are certainly not listed to be used with pieces of solid wire!
Steve Swaffer
« Reply #6 on: March 31, 2018, 09:32:05 AM »
You might be surprised by how much current that takes... About a year ago I needed to DIY a small fuse to get an amp working until replacement fuses arrived. I macgyvered a single stand of the smallest wire I could find (30ga?) tacked across the blown fuse, but decided to look up it's fuse current and that was close to 10A IIRC.  :o
 (BTW kids don't do this at home).
Kevin Graf
« Reply #7 on: March 31, 2018, 03:17:23 PM »
Yep, fusing current for copper wire:
30AWG  ::  10.2A
12AWG ::  235A
Speedskater
« Reply #8 on: April 01, 2018, 06:07:30 AM »
30AWG  ::  10.2A
12AWG ::  235A
Those values are in free air, right?
Sent from my VS995 using Tapatalk
Kevin Graf
« Reply #9 on: April 01, 2018, 09:09:31 AM »
Based on Preece  and Onderdonk.
https://www.powerstream.com/wire-fusing-currents.htm
Speedskater
Pages: [1] 2 3  All   Go Up
Page created in 0.077 seconds with 23 queries.
