Pages: 1 2 [3]  All   Go Down
Author Topic: What does it take to run AC and signal in the same box?  (Read 7019 times)
Steve M Smith
  • Isle of Wight - England
Re: What does it take to run AC and signal in the same box?
« Reply #20 on: April 06, 2018, 07:27:10 am »
No inductive hum.
Or some you are not aware of as common mode rejection hides it. Either way, not a problem!
Steve.
Bob Leonard
  • Boston, MA USA
« Reply #21 on: April 06, 2018, 01:45:09 pm »
Code doesn't allow mixing of "services" in the same box, but IIRC the box can have a divider so long as each service remains on its respective side.  The idea is the divider makes each side its own "box" for the purpose of splicing or terminating.  The sides cannot share a common cable entry or exit, I think.
Not sure of the current Code as my book is from a previous decade... but Chapter 3 is Wiring Methods & Materials, Articles 312 and 314 cover meter bases to junction boxes.  I think what you're looking for is in there.
It's not hum that will shut down the show. It's the one in a million chance that a real inspector see's the box and tells you to remove it. Or maybe the slight chance of fire or electrocution. This is the very reason you'll be very hard pressed to find an outlet cover that supports both A/C and low voltage audio or video signals. Not allowed in this state under any circumstance.
BOSTON STRONG........
Proud Vietnam Veteran
Frank DeWitt
    • LBP DI Box
Not to Code
« Reply #22 on: April 08, 2018, 11:22:06 am »
Pages: 1 2 [3]  All   Go Up
Page created in 0.049 seconds with 24 queries.
