Pages: 1 ... 8 9 [10]   Go Down
Author Topic: Combiner quality  (Read 11592 times)
Steve Litscher
    • 608 Sound and Light
Re: Combiner quality
« Reply #90 on: August 20, 2019, 06:35:58 pm »
What all did you learn?
We talked for a good 15 minutes or so, about a number of RF-related items, so it's hard to summarize it all, but the key take-aways (and, I'm *super heavily* paraphrasing here):
- RG8X cable (double-shielded) provides better protection against noise; use if you can
- Don't bundle/wrap antenna cables together in rack; leave loose
- If you can get away with it, run the PSM 1000 at lower power and let the Combiner/antenna help out with gain
- If using Shure WWB to scan frequencies, include +/- 50 MHz from target range - it'll help it make a better decision
- Really would be better to have a dedicated RF scanner, but WWB can do the trick
We talked a little about the technology differences and also talked about interference sources, common issues, etc.. Again, I'm distilling-down a bunch of info into a few bullet-points, so take it for what that's worth. Don was super helpful and I hope I'm not over-simplifying too much.
Henry Cohen
  • Westchester Co., NY, USA
« Reply #91 on: August 20, 2019, 10:09:15 pm »
RG8X is not a specification for double shield; in fact most RG8X manufactured is a single 95% shield. To get a double shielded .24" OD (RG8X size equivalent) coax, you must look for coax that explicitly states it's double shielded (e.g. Times Microwave LMR240).
However, for transmit applications, even if only a 25' length, a double shielded .405" OD coax (LMR400, Belden 9913F7, PWS S3018 and S9046) is still a better choice due to lower losses, which are more significant as a percentage of ERP.
Henry Cohen
Don Boomer
    • RF Venue
« Reply #92 on: August 22, 2019, 11:22:10 am »
Sorry ... I forget that because our RF Venue RG8x is double shielded with a braid and a foil shield that everybody doesn’t do it that way. 😁
Don Boomer
Senior applications engineer
RF Venue, Inc.
Steve Litscher
« Reply #93 on: August 22, 2019, 02:26:17 pm »
I purchased the RFV RG8x cable for my CP Beam, so whew - all good!
Pages: 1 ... 8 9 [10]   Go Up
Page created in 0.035 seconds with 24 queries.
