Author Topic: Crown XTi 6002 Security Cover  (Read 1643 times)
Robert Weaver
« on: March 01, 2018, 09:44:00 pm »
I ordered a security cover for the Crown XTi 6002 amp.  Upon installing the cover I discovered the cover doesn't fit due to the pullout handles of the 6002.  Does anyone know of a cover that will work?
Mike Caldwell
  • Covington, Ohio
Re: Crown XTi 6002 Security Cover
« Reply #1 on: March 01, 2018, 10:17:24 pm »
You can lock out the front panel menu buttons using the System Architect or Band Manager, but someone can still turn the knobs.
To put a security covers over equipment with handles a couple times like an XTI amp I used longer 10/32 screws, cut the heads off and used a nut to tighten up to the piece of equipment and double nuts to hold the security cover, not real elegant but it worked. If I was doing a lot of those I would some threaded studs with male threads to screw into the rack and female threads on the other end to screw the cover to.
Robert Weaver
« Reply #2 on: March 01, 2018, 10:28:23 pm »
Some 10-32 hex standoffs with a washer might work if they were long enough.
Page created in 0.036 seconds with 23 queries.
