Pages: 1 2 3 [4]   Go Down
Author Topic: Non-Tripod Speaker Stands  (Read 7953 times)
David Allred
Re: Non-Tripod Speaker Stands
« Reply #30 on: February 14, 2018, 04:53:44 pm »
One element of using a circular base is that it is very difficult to level on an uneven surface as compared to a tripod, especially a tripod with an adjustable leg such as the Global ST-132 that accounts for uneven surfaces.
To boot, a flat piece of metal that size ain't flat (without paying a huge (HHUUUGGGEEEE) amount of money).  Wobble city.  2nd to boot, floors ain't flat.  3 contact points is the only way to avoid a wobble, so the round plate will still need 3 rubber feet.  Back to being a tripod, a very sleek low-profile heavy tripod nonetheless. :)
Tim Hite
    • Bad Quail
« Reply #31 on: February 14, 2018, 05:10:30 pm »
. . .I'm wondering if there's something like this that will hold that much weight. . .
I have the K&M 480mm square bases with 26736 distance rods. I use them with RCF TT52a speakers. They go way up and are small enough to squeeze into a corner. While this setup is rated to hold the weight of your JBL tops, I would be remiss to put that much weight that far up because of leverage issues already mentioned. I use the setup for wedding ceremonies and such where there will be no foot traffic nearby. Tripods for anything else.
Column array with a sub would be my preference if I needed to get louder and be on a dance floor. Get more low end having the sub on the floor and easier to set up with smaller tops going up.
Bad Quail
Sound + Light
Joshua Tree, California
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
« Reply #32 on: February 14, 2018, 11:14:34 pm »
Yes, my ultimate plan is to eventually get two SRX818SP subs to go with my current system for larger events, and a smaller column array system for smaller events. Unfortunately that's a lot of money for my small sole proprietor business that does 40-50 events per year as a side job! :o
Good call. Thanks.
I can't stand the glowing teepee look. It's terrible. See what I did there? ;) I've considered just getting some black fabric to cover the tripod legs instead though.
I have both white and black covers for tripod stands.
Wedding receptions get the white with a soft glow of the bride’s color.
Corporate gets black.
Scott Olewiler
    • 4th Street Sound
« Reply #33 on: February 15, 2018, 01:17:20 pm »
Concerning the round base:
I also wonder when it does get pushed past the point of no return; does the base becomes a wheel and the speaker might go in any direction at that point?
Chris Hindle
« Reply #34 on: February 15, 2018, 01:27:46 pm »
I would  expect the speaker (load) to be in such a hurry to reach the ground, that the shape of the base won't mean much.
Chris.
Dave Garoutte
  • San Rafael, CA
« Reply #35 on: February 15, 2018, 03:43:33 pm »
Kind of like Fred Astair (or was it Gene Kelley) dancing with the mic stand.
Bob Leonard
  • Boston, MA USA
« Reply #36 on: February 15, 2018, 09:53:50 pm »
And they look incredible. Just ask my daughter.
BOSTON STRONG........
Proud Vietnam Veteran
Joe Pieternella
« Reply #37 on: February 16, 2018, 07:35:03 am »
It will, especially if it "wiggles" back and forward or side to side or any direction for that matter.
But it won't be much and I believe the height of the pole in relation to the size of the base also has an influence.
OH and don't ask why I know
Verstuurd vanaf mijn G8341 met Tapatalk
Craig Leerman
  • Global Moderator
  • Do Not Read This!
« Reply #38 on: February 16, 2018, 02:56:56 pm »
While I still use tripods (Older Hamilton steel leg units) on some events, for the most part I use Altman 55 pound bases and steel pipe. The bases take a 1 1/2” pipe and I made some reducer couplings to 1” pipe to fit the speakers. A small wrap of gaff around the 1” pipe makes the fit snug.
For heavier speakers on tall pipes I put some sandbags on the base and cover the sandbags with a piece of cloth like some banjo drape. I always have a bunch of banjo on gigs to dresss things up.
My corporate clients like the look of the pipe and base stands and I never have a tripod leg sticking out in the walkway to trip over.
I made different height pipes for various speakers.
The picture shows a Renkus-Heinz RH62, Carvin 3903 columns, Ramsdell 10CX coax monitor and Alto 15” Truesonic cabs on the stands. I also use the stands with my Danley SM60s and smaller Altos.
Craig
Sent from my iPad
TechWorksReno.com
Facebook.com/TechWorksReno
Pinterest.com/TechWorks0492
Pages: 1 2 3 [4]   Go Up
Page created in 0.049 seconds with 23 queries.
