Author Topic: JBL SRX800 series 828sp-835p Weird "sucking" feeling on Eardrums  (Read 4278 times)
Jack Murry
« on: February 12, 2018, 07:19:46 pm »
So I recently purchased  the JBL SRX 828sp's with matching 835p's (powered) speakers for my bands new P.A. and I am having a hell of a time dialing them in.... The last two gigs as I walked around the club on my wireless at volume for mid sized club, I have been noticing a weird sucking sensation on my eardrums?  ...We dont have a soundman so we run the board (Presonus 24.4.2 StudioAI) on the stage...  Also (its hard to articulate) but its like our instruments arent cutting through like I want them to and I know this system is capable of the sound I am looking for.... I know this is limited info but If anyone has any advice? I know the "sucking" sensation is a big part of it. Sub DSP set to SRX top, Tops set to SRX sub  ...crossed 80hz. Sensitivity presets are on "line" ...pretty much out of the box settings
As I side thought: It seems that this sucking sensation only happens when our band is playing, not so much during the break music.
 If you need more information to offer a suggestion I can try to answer specific questions
Thanx you guys
Gordon Brinton
  • ID Verified
    • Raw Depth Sound, Harrisburg, PA
Re: JBL SRX800 series 828sp-835p Weird "sucking" feeling on Eardrums
« Reply #1 on: February 12, 2018, 07:51:08 pm »
Gee, that really sucks.
Maybe the "Suck" knob is turned up too high.  ;D
But seriously...
I have no idea what you are talking about, but I'll make a rough assumption that maybe there is a phase issue somewhere in the system. That can sometimes make things sound weird.
« Last Edit: February 12, 2018, 07:56:20 pm by Gordon Brinton »
Member since 2005.
  • Old enough to know better
  • Audio Plumber
« Reply #2 on: February 12, 2018, 08:46:11 pm »
In my experience, if you are experiencing weird pressure sensations you have speakers out of polarity. I would go through your whole setup 1 speaker at a time and determine the absolute polarity of each speaker. Any speakers of the same type should have the same polarity.
William Schnake
    • Schnake Sound & Light
« Reply #3 on: February 12, 2018, 09:25:05 pm »
Best advice you will ever get.  +100
Bill Schnake - Owner Schnake Sound & Light
Avid/Crown/EAW/EV/Midas/RCF/Shure/Yamaha
schnakesound.com
Jack Murry
« Reply #4 on: February 12, 2018, 10:16:19 pm »
I thought about that. Ive had the speakers for less than 6 months with maybe 50 hours on them. They are literally right out of the box ....How do I test the polarity of the speakers?  Do I have to open up the cabinets?  Do you know if the subs are out of phase with the tops would create a similar symptom?
  • Audio Plumber
« Reply #5 on: February 12, 2018, 10:29:20 pm »
It could be a cable, either a speaker cable or a signal cable in any part of the signal path. It could be a polarity switch in the console. It could be an amp switched to bridged mode. It could be in the cabinet. You really have to test every part of your system.
I would not expect that result from a sub to mains out of polarity since the 2 speakers don't cover the same spectrum. I would suspect the subs, or the low section of the mains, but if the problem was with the subs that does not mean the speaker is the problem. The whole system needs to be tested.
« Reply #6 on: February 13, 2018, 12:13:36 am »
The speaker system is self-powered.  I'm putting my bet on an XLR cable with pins 2/3 swapped at one end.
We need more details about how Jack hooks up the rig.
Chris Grimshaw
  • Sheffield, UK
    • Grimshaw Audio
« Reply #7 on: February 13, 2018, 03:38:55 am »
+1.
Disconnect one of the subs, see if that improves matters. Sounds to me like the subs aren't working together.
Chris
www.grimshawaudio.com
Jack Murry
« Reply #8 on: February 13, 2018, 03:54:42 am »
Thanx for the replies
Yes they are powered .... XLR from the board. You said pins swapped? Is that something that can happen from the factory the cable was manufactured at? I can give you more info on how I have it all set up but its pretty straight forward. Board outputs (Presonus Studiolive 24.4.2 AI) to bottom subs Ch. 1  ...then short jumper XLR's to Ch. 1 on the tops... But if you want more info I can provide if I know what you need
John Ferreira
« Reply #9 on: February 13, 2018, 01:11:54 pm »
If you output a single sine wave at 60Hz from any device (iPhone app) and then disconnect 1 sub (they should be side by side), if it gets louder your polarity is reversed in one of them.
John Ferreira
Page created in 0.072 seconds with 19 queries.
