Pages: 1 2 [3] 4 5   Go Down
Author Topic: Highest Output Powered Single 18" sub....  (Read 7282 times)
Richens Lance
Re: Highest Output Powered Single 18" sub....
« Reply #20 on: February 11, 2018, 10:28:05 pm »
Lance, do you have another email address. The one you sent me is the one you are already registered at.
Whoops. New pm sent
Steve Crump
« Reply #21 on: February 11, 2018, 10:39:28 pm »
Since a sub other than an 18 has been mentioned. The JTR Captivator 212 Pro is a great option to look at within these specs.
Richens Lance
« Reply #22 on: February 11, 2018, 10:55:59 pm »
Those look great, but I already have 4 SRX 728's. I'm looking for a small form factor, front loaded, powered sub that comes in not heavier than 110 lbs or so and is set up to pole mount a mid/hi cabinet....
Steve Crump
« Reply #23 on: February 11, 2018, 11:04:52 pm »
http://jtrspeakers.com/captivator-212pro.html
Its pretty small, smaller than some of the single 18s listed, front loaded, 75 pounds, active, has a center pole socket.
« Last Edit: February 11, 2018, 11:15:28 pm by Steve Crump »
Paul G. OBrien
« Reply #24 on: February 11, 2018, 11:19:42 pm »
What about the Bassboss SSP118, it's a touch over your maximum weight but appears to have a real output advantage over the JBL 818. Here is a link to a comparison graph of those two boxes. https://www.bassboss.com/discussion-community/?p=post%2Fssp118-powered-subwoofer-vs-the-jbl-srx818-sub-7843671
Richens Lance
« Reply #25 on: February 11, 2018, 11:28:10 pm »
My bad, I thought it was a 2 18" box
Robert Lunceford
« Reply #26 on: February 11, 2018, 11:33:23 pm »
Hi Lance,
The most compact, lightest, 18" powered sub that I know of is the K-Array KMT18 Thunder.
It is in the pro class (not MI) and is priced accordingly.
Here are the manufacturers published specs:
18.3" X 18.3" X 23.46"
60.84 lbs.
30-150Hz -3dB
Max SPL 130dB(cont) 136dB(peak)
1W/1Meter 99dB
https://www.k-array.com/phocadownload/Products/Portable/KMT18/KMT18_I_Datasheet_Ver2_Rev0.pdf
Richens Lance
« Reply #27 on: February 11, 2018, 11:37:37 pm »
WOW! Those sound like they'd be amazing. However the price is just too high for me. I can buy two JBL's for the price of one of those monsters. If price was no issue, I would definitely give them a try....
Richens Lance
« Reply #28 on: February 11, 2018, 11:48:20 pm »
Hi Lance,
60.84 lbs.
30-150Hz -3dB
1W/1Meter 99dB
Another super nice box! I like all the built in flexibility and options. But sadly, way out of my price range.
Johan Falt
    • http://www.lucas.se
« Reply #29 on: February 12, 2018, 02:18:45 am »
What about Yamaha DXS18
Pages: 1 2 [3] 4 5   Go Up
Page created in 0.055 seconds with 22 queries.
