Author Topic: Dampness in House of Worship  (Read 3915 times)
Gary Fitzpatrick
  • Fermanagh, Ireland
« on: January 12, 2018, 01:20:09 pm »
I have been tasked to deal with a recurring problem in a chapel close to me. There are three XLR sockets located on a small step up to the main sanctuary part of the church. One of these sockets seems to suffer from rising damp. About three years ago I covered the solder connectors on the socket with "Wonder Gel" (http://www.raytech.it/product/low-voltage/wonder-gel?lang=en). This insulating gel cured the problem, but it is back again, despite the gel. Is there any other solution for insulating the connectors on the back of the xlr faceplate?
Allen Heath GL2000, EV sx300 over Community pro Subs, EV s-200 monitors, Zeck amplification
David Allred
Re: Dampness in House of Worship
« Reply #1 on: January 12, 2018, 01:24:30 pm »
Is it in a plenum or directly exposed to conditioned cold air that might cause temp differential and condensation?
Gary Fitzpatrick
« Reply #2 on: January 12, 2018, 02:11:32 pm »
Itís sunk directly into the concrete floor. Cables are run inside buried conduit.
Chapel is only heated for two hours per day which is adding to the problem
Adam Kane
  • Battle Creek, MI
« Reply #3 on: January 12, 2018, 04:40:26 pm »
The condensation is coming inside the conduit...which is pretty common. Try closing the end of the conduit off with expanding foam or silicone. Makes it a bit of a pain to pull additional wiring through later, but helps keep the moisture out of the box.
Gary Fitzpatrick
« Reply #4 on: January 13, 2018, 05:35:44 am »
That would make sense. Yea I will try that. I wonít be pulling any cables anytime soon so it doesnít bother me
Joseph D. Macry
  • Austin TX
« Reply #5 on: January 19, 2018, 10:34:08 am »
I would suspect there is standing water inside the underground conduit. Can sometimes be cleaned out with a shop vac, but hard to get a good seal with cable in the way.
Joseph Macry,
Austin, TX
« Reply #6 on: January 19, 2018, 10:51:57 am »
I would blow it out with a compressor rather than try and suck it out.
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
« Reply #7 on: January 19, 2018, 02:05:31 pm »
I would check the other end to see where the water will spray
« Reply #8 on: January 19, 2018, 02:53:38 pm »
What Rob said, it can be putrid too
Erik Jerde
« Reply #9 on: January 19, 2018, 08:13:53 pm »
Iíd just grab a block of duct seal and shove some of that in there.  Thatís what itís for and itís not the pain-in-the-ass that foam or silicone would be.  You can get it at Home Depot or your electrical supply shop.
¬ę Reply #9 on: January 19, 2018, 08:13:53 pm ¬Ľ
Page created in 0.054 seconds with 22 queries.
