Author Topic: Multi-voltage Distro  (Read 3867 times)
Mike Sokol
Re: Multi-voltage Distro
« Reply #10 on: December 31, 2017, 07:53:55 am »
Yes, you can get distro assemblies with both 240v and 120v recepticles. Motion Labs is one reliable brand; Indu-Electric is another. Both make listed, code compliant devices. Whether or not they have a standard model that meets your needs is another question. You might need a custom panel to give you what you want.
Whirlwind makes all kinds of custom rack-mount distro panels with both 120-volt and 240-volt receptacles. You can get Edison or PowerCon outlets on the 120-volt side, as well as a variety of twist-lock and feed-thru configurations. See http://whirlwindusa.com/catalog/power-electrical-distribution/distro/plr-distros for the catalog.
Mike Sokol
mike@noshockzone.org
www.NoShockZone.org
TJ (Tom) Cornish
  • St. Paul, MN
« Reply #11 on: January 03, 2018, 04:13:58 pm »
As for ML, WhirlWind, EMG, etc- for an assembly to be UL listed, they have to submit the overall design of (the distro, rackpack, etc) to the UL people for certification. So, they're less apt to do truly custom work (as in a RackPack that takes a special connector in or creates a special mix of outputs, beyond what they already have publicized on their website), since the UL-certification would be cost prohibitive for a one-off or limited production run item.
I am not a UL expert, but I just submitted an order to Whirlwind for several power distribution items, none of which are specifically listed on their catalog (different combinations of IO than stock modules), but all will be UL-listed.  Apparently they don't have to submit each detailed config to UL if they follow certain construction parameters.
On a related note, Whirlwind's new SKB case distros might be good options for a lot of people - half the price of a rack distro and 20% of the weight.  No main breaker and no metering, but a nice intermediate step between spider boxes and full-bore rack distros.
http://whirlwindusa.com/catalog/power-electrical-distribution/distro?product-family=plr-skb
Pierre Foster
« Reply #12 on: January 04, 2018, 04:31:24 pm »
Thanks for all the info guys, I think I just need to look at my power needs differently. What I had in mind would likely have to be a custom build so it's back to the drawing board for me.
TJ (Tom) Cornish
  • St. Paul, MN
« Reply #13 on: January 04, 2018, 05:15:42 pm »
As I posted above, custom isn't necessarily prohibitive, assuming what you want is a legal configuration.  Call up Whirlwind and/or MotionLabs and I'm sure they can both help you.
brian maddox
  • HeyYahWon! ttsss! ttsss!
« Reply #14 on: January 04, 2018, 07:57:13 pm »
Our company recently had a custom distro built by MotionLabs and i was SHOCKED at how cheap it was.  I've used their stuff for decades but i've always thought it was much more expensive than it actually is.
Granted, it was someone else paying for it.  They might not have seen it precisely as i did....
brian maddox
bdmaudio@gmail.com
Page created in 0.084 seconds with 22 queries.
