Pages: 1 ... 3 4 [5] 6 7   Go Down
Author Topic: Couldn't Stop Mic Peaking  (Read 12191 times)
David Sturzenbecher
  • So. Dak.
    • Sturz Audio
Re: Couldn't Stop Mic Peaking
« Reply #40 on: December 13, 2017, 12:24:31 pm »
According to the block diagram, this is not the case.
There is no pad shown between the TRS jack and the preamp; it is simply the users choice of connection.
That being said, there should be no issue if the OP sets the receiver output to Mic level and adjusts the preamp gain as needed.
I find that “normal” speech has my QLXD receiver gain set at +10, which has my levels on the unit in the green and tickling yellow. I’d set it lower for very dynamic speakers, maybe at “0” and compensate at the console.
The noise floor with stable RF should be low enough to not cause any issues.
Jordan,
If you look further down on the technical data sheet you will see a 10dB input sensitivity different between the XLR input and the TRS. So there looks to be a 10dB pad on that 1/4" input.
Retyped from the spec sheet:
Input sensitivity (XLR/TRS)
-60 to +5dBu / -50 to +15dBu
Sent from my iPhone using Tapatalk Pro
Audio Systems Design Engineer
Daktronics, Inc.
CTS-D, CTS-I
AES Full Member
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
« Reply #41 on: December 13, 2017, 03:53:44 pm »
Jordan,
You can see the two resistors on the line level inputs (the little rectangles) just as there are also resistors from the phantom power to the mic inputs.
Mike Caldwell
  • Covington, Ohio
« Reply #42 on: December 13, 2017, 06:18:34 pm »
What does the audio level metering show on the receiver, if it is overloaded and distorted at the receiver nothing is going to fix that downstream of the receiver.
I'm not that familiar with the QLXD series and it does not look there is traditional transmitter gain/level adjustment on the body other than the mic level offset adjustment.
When you make level adjustments on the receiver do you need to re sync the transmitter to pass any needed level adjustments on to the transmitter?
« Reply #43 on: December 13, 2017, 08:30:19 pm »
No there is a rocker switch in the battery compartment to add gain at the mic (call offset) and adjust other settings.  On the receiver the gain is adjusted by up and down buttons on the front panel with the results on the display.
Stephen Swaffer
« Reply #44 on: December 13, 2017, 09:10:45 pm »
I have always assumed that any settings on the mic/transmitter were intended to match the mic (lavalier, headset or a different headset, instrument DI) to the transmitter so you don't clip the audio to the RF signal.
Adjustments on the receiver are intended to make it work with whatever you are sending the signal to.
Correct?
Steve Swaffer
Geert Friedhof
« Reply #45 on: December 14, 2017, 08:26:44 am »
^  #MeToo
Chris Hindle
« Reply #46 on: December 14, 2017, 08:33:05 am »
^  #MeToo
^ MeTree.
If the receiver is clipping, there is nothing you can do on the console.
Chris.
Jordan Wolf
« Reply #47 on: December 14, 2017, 09:47:48 am »
Jordan,
If you look ...
Ah, my apologies to all! The drawing does indeed show resistors (and the spec sheet bears that out as well).
This lack of sleep thing isn’t doing me any favors...
Jordan Wolf
Isaac South
  • Central Kentucky
« Reply #48 on: December 14, 2017, 01:26:06 pm »
So, how do I know how far to turn the receiver down and how far to turn the mic down?  Should I just experiment, or is there a suggesting starting place?
Rob Spence
« Reply #49 on: December 14, 2017, 02:04:22 pm »
Experiment.
If only very loud talking creates the problem, turn it down a little. If moderate volume causes the problem, turn it down more.
You can test immediately if you can cause the problem yourself.
Pages: 1 ... 3 4 [5] 6 7   Go Up
Page created in 0.058 seconds with 22 queries.
