Pages: 1 [2] 3 4   Go Down
Author Topic: 5 Megawatt Load Bank  (Read 7443 times)
Steve Alves
  • South Florida
    • South Florida Sound
Re: 5 Megawatt Load Bank
« Reply #10 on: November 17, 2017, 02:14:01 pm »
So you're saying I could roast marshmallows over it like a campfire? That's another win in the plus column...  ;) BTW: Just how many watts does a campfire output?
The average campfire (not bonfire) produces 4,700,000 BTU. Using an online calculator (1 BTU/hr = 0.29307107 W) that shows as 1,377,434.029 Watts.
Steven Alves
South Florida Sound, Fort Lauderdale, FL
www.southfloridasound.com
« Reply #11 on: November 17, 2017, 02:47:23 pm »
So Mike would have the very expensive equal (think of his electricity bill) to about 4 campfires.
Burn wood, Mike.
Mike Sokol
« Reply #12 on: November 17, 2017, 02:51:37 pm »
I think you're confusing BTU Hours with BTUs, so at the very least you need to divide your total watt output by 60, maybe more. I'm pretty sure a campfire doesn't put out more than 1.3 megawatts of heat, but maybe it does 23kW. Can somebody check the equation and math?
Mike Sokol
mike@noshockzone.org
www.NoShockZone.org
Art Welter
« Reply #13 on: November 17, 2017, 03:17:06 pm »
Wood has anywhere from about 8000 to 9700 BTU per pound, depending on resin content. If we go for the highest BTU at 9700 x a 10 pound campfire, the total BTU output would be around 97,000, with the output spread over a time period depending on how the fire was made and tended. Lets say a fast burn, 1 hr=97,000 BTU =28KW.
« Last Edit: November 17, 2017, 03:25:32 pm by Art Welter »
Stephen Swaffer
« Reply #14 on: November 17, 2017, 06:35:55 pm »
So, do you have large enough feeders to hook it up?
Steve Swaffer
Mike Sokol
« Reply #15 on: November 17, 2017, 08:01:27 pm »
I've got a 2/0, 3-phase, 120/208 feeder, so in Y mode that's 200 amps x 120 volts x 3 legs = 72,000 watts. That's only 1.44% of 5 MW. But in Delta mode that's 200 amps x 208 volts x 3 legs = 124,800 watts. That's still only 2.4% of 5 MW if I'm doing this right. I don't think that would even warm up this load bank up enough to spin the fans. But I can dream, can't I?  ;D
Mike Sokol
www.NoShockZone.org
Stephen Swaffer
« Reply #16 on: November 17, 2017, 09:18:39 pm »
Of course, the point of a load bank is to test the cable to see if they warm up under load...
Tap into 480 and you can do a tiny bit better-get the right medium voltage feed and you can make some headway-though arcing might pose a problem.
Steve Swaffer
David Buckley
« Reply #17 on: November 19, 2017, 06:07:47 pm »
You can fry stuff up on a frypan on top of a 1K parcan.  You can torch stuff with a few well-aimed sharpies.  A 200KW fan heater will carbonize your marshmallows in a blink of an eye.   Assuming (a) the marshmallows could be persuaded to stay on the sticks, because you are talking about a significant amount of airflow here,  and (b) as long as the sticks were a many feet long, otherwise your body will also be in the jetstream, and will also be toasted to a crisp.
Load banks are mean pieces of engineering.
Erik Jerde
« Reply #18 on: November 19, 2017, 09:44:59 pm »
I just found the ANSI definitions. So 99.9 kV is considered "Medium" voltage. Holy crap...
Voltage classes: (ANSI C84.1-2016)
Low Voltage: 1000 volts or less
Medium Voltage: greater than 1000 volts and less than 100 kV
High Voltage: greater than 100 kV and equal to or less than 230 kV
Extra-High Voltage: greater than 230 kV but less than 1000 kV
Ultra-High Voltage: equal to or greater than 1000 kV
And the dielectric strength of air is 33Kv/cm so in those upper ranges things can get exciting real fast when you're not careful.
David Buckley
« Reply #19 on: November 19, 2017, 10:19:17 pm »
So next time you see a "DANGER HIGH VOLTAGE" sign on a door, chances are, it isn't really.
Pages: 1 [2] 3 4   Go Up
Page created in 0.104 seconds with 25 queries.
