Author Topic: Soundcraft SI Expression - EQ settings for monitors different than main buss?  (Read 3509 times)
Steven Gregory
Hey All.
Question regarding Soundcraft SI Expression 1, (16 chan)
Is it possible to create monitor mixes with different  EQ settings than those set in the main (LR) buss.?
EX: nice warm EQ for the mains and a bit brighter and less bottom for the stage wedges.
Can someone walk me through that?
Thanks.
Joel Mevis
Hey All.
Thanks.
I have an SI Impact but it should be the same.
Select the Mix you want to edit (faders should turn orange/yellow).
Press the select button on the L&R or Mono, which ever one glows. I don't remember exactly I think its mono though.
Then adjust eq/compression etc on that mix.
Or you could then adjust the GEQ of that mix.
Another way to do it, is to go to what ever page all your aux mixes are on. Page C maybe?
Press the select button under the mix number you want and then adjust the Eq.
Hey All.
Thanks.
You can "voice" the individual monitor MIXES with output EQ.  Shelf-filtering the wedge mixes, -6dB @ 200Hz - give or take - will clear up much of the mud you get from the LF coupling of the wedge's LF with the stage floor.
The alternative is to assign more than 1 input strip to the same physical input; use 1 strip for FOH mixing and another set for post EQ sends, and use that input strip to send to monitors.  This allows you to have completely separate channel strip EQ for FOH and monitors but it also has some drawbacks - there is only 1 preamp for each physical input so you don't have independent input gains; you need to keep them organized in your mind (and labeled) as to which input strips are mains and which are monitors... but you'll have full channel strip EQ for the inputs going to monitors, which can be a really big help (and does not change the need to use the MIX output EQs for feedback control and mix voicing).
Steve Ferreira
Tim hit the nail on the head. OP watch this video to give you a better understanding https://www.youtube.com/watch?v=L5HVYx1Pq7w
Bob Leonard
  • Boston, MA USA
As has already been said. Create a group/MIX 1-14. Assign an output to the mix. i.e. output 6 for mix 6. Run that output to the IEM or monitor amp. Assign members of the group (every channel if you want). Press the MIX button for the mix you want. press the EQ high/low button. Adjust to taste. You can set the EQ for every mix and every output.
BOSTON STRONG........
Proud Vietnam Veteran
Steve Ferreira
Bob,
That works for a general mix EQ. If you want an individual channel strip eq'd to taste you would need to go the double patch route. The video I posted gives a good explanation on it.
Dave Garoutte
  • San Rafael, CA
Bob,
But that's what the OP asked about.
Inventor.
Bob Leonard
  • Boston, MA USA
Bob,
Correct. My fault thinking group eq.
« Last Edit: November 08, 2017, 07:18:11 am by Bob Leonard »
Branimir Bozak
  • Stara metalika
No, but you could assign some other channel the same inputs, um... doubling... For instance, if you have a regular band, for instance, 14 channels, you have them on your first layer, and on the second layer the channels 15 - 28, assign inputs 1 to 14, and use that layer for monitors.
Channels share the gain, but you can eq them differently, apply compressor, etc...
Quite useful, at least for vocals, I do it all the time with vocals...
If you scoop, it sounds like poop!
Page created in 0.041 seconds with 22 queries.
