Pages: 1 ... 8 9 [10]   Go Down
Author Topic: Gym Speaker Setup - Project Completed merged  (Read 17922 times)
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
Re: Gym Speaker Setup - Project Completed merged
« Reply #90 on: May 06, 2018, 03:43:29 pm »
I called the electrician and asked about this specifically. When they installed the outlet the rack and equipment was already installed. They were well aware of the usage and placement.  I trust their judgment. At some point flexible wire will be used to supply power to the rack and equipment. Its not like flexible wire was used to power an installed outlet.  I wasnt about to modify the wire on the sequencer and void the warranty. There is no room for a plug inside the rack. The only other option was to create a flexible extension with proper plugs on each end.
If there is no room in the rack, then the rack is the wrong size. As Scott said, run EMT down from the box above (no bends needed) and into the rack where a 4 shallow box and outlet or a plugmold could be placed.
« Reply #91 on: May 06, 2018, 06:57:28 pm »
Rob is spot on.
One other item (I reviewed the pictures) nothing screams amatuer like a consumer grade wireless.  Poor performance sitting on top of the rack.
I would suggest while the EMT is being installed you put another length in to a quad box at least 24" from any significant metal.  Mount another quad box and use a Ubiquity Uni-fi Pro.  It the best sub $100 access point on the market and it has all the big boy features (central management, vlan trunk support and multi-SSID capabilities).
Robert Weaver
« Reply #92 on: May 06, 2018, 08:29:59 pm »
Rob is spot on.
The antennas you see are for the AT3000 wireless mics. Those are going away next year as they are 600mhz. Thats also my old laptop sitting on top.
« Reply #93 on: May 06, 2018, 08:43:05 pm »
Why are the antennas oriented like that?
I assume you put bulkhead connectors in.  There are some more sophisticated antennas but if they work you should be good.
I would suggest moving the antennas to the side if you are having any coverage issues.  That much metal in the near field is going to distort the antenna pattern.
Robert Weaver
« Reply #94 on: May 06, 2018, 10:45:46 pm »
I put them down like that in the event a ball goes over there.  Less likely to damage them.  Those are just to get us through this year.  I havent had any coverage issues.  I do have them attached with bulkhead connectors.  Those antennas run to an older distribution system that powers the wireless receivers. I'm going with 2 more of the System 10 Pro dual units next year when I phase out the AT3000's.
« Reply #95 on: May 06, 2018, 10:49:06 pm »
When you get the new system cruise over to the RF forum and they can help you out selecting an enclosed radome antenna that will protect from errant balls.
Pages: 1 ... 8 9 [10]   Go Up
Page created in 0.041 seconds with 23 queries.
