Author Topic: bases for truss and pipe in one?  (Read 3759 times)
Nathan Riddle
  • Niceville, FL
    • Nailed Productions
Re: bases for truss and pipe in one?
« Reply #10 on: August 24, 2017, 06:45:11 pm »
i want to be able to use the same bases for truss with projectors on top and poles with lighting on top.  if it seems safe,and i can do both from the same location,  Id like to have an offset pole threads so I can put a projector on a top plate and 2 lekos on a pole on one base.
All of this would be very light weight.  50lbs for projector, 50 lbs for 2 lekos.
So both pole and truss on the base plate at same time?
I was imagining pipe'n'drape being used with the base as well as trussing (multi-use baseplate of sorts).
Why not just get a swivel coupler and clamp the pipe to the truss?
https://www.kpodj.com/2x-global-truss-swivel-clamp-n-p-105148/
Make sure to offset the weight difference & the pipe needs to be ~2" OD to work
John Fruits
« Reply #11 on: August 24, 2017, 06:58:00 pm »
In another recent post here I mentioned tank traps, and linked to this company:
http://www.doughty-engineering.co.uk/shop/147/index.htm
Take a look at the 3 position tank trap. If you are using spigoted truss it's close to what you want.  Downside its only a 24 inch base.  Doughty US doesn't show this product, but you could always give them a call.  One plus for a tank trap is you don't have to worry about cross threading a pipe flange.  Quicker to set up too.
"The music business is a cruel and shallow money trench, a long plastic hallway where thieves and pimps run free, and good men die like dogs.  There's also a negative side."-Hunter S. Thompson
Mark Cadwallader
  • Helena, Montana USA
« Reply #12 on: August 25, 2017, 01:57:46 am »
Global Truss 30"x30" aluminum base plates use a flathead hex socket ("Allen") cap screw to hold the half couplers in place. They are M8 cap screws IIRC (6mm allen wrench).  Use that same size if you want to bolt a flange to the baseplate. If you want more thread depth for engagement, have a collar (threaded pipe connection) welded to 1/4"'steel plate and bolt the plate/collar assembly to base plate.  Off-set the location on the baseplate as desired to decrease the likelihood of tipping.
There are other fabrication options, if you want to get fancy about how it looks when the threaded collar is mounted to the baseplate. I can see a way to do it with just one extra bolthole in the baseplate, and no visible hardware exposed.
Tim Weaver
  • College Station, Texas
    • Daniela Weaver Photography
« Reply #13 on: August 25, 2017, 10:32:43 am »
I've seen bases that were welded out of steel. They had an outer "square" and an "X" running through the middle. The truss could bolt through the X brace and in the middle was a pipe thread. I'm sure you could have these made by a shop pretty easily.
(Brian) Frost
« Reply #14 on: August 25, 2017, 05:45:47 pm »
i like this plan and with a few added holes I could change positioning of the pipe depending on use.
Mark Cadwallader
« Reply #15 on: August 25, 2017, 06:50:51 pm »
If you go with a one-bolt option, it probably needs to be an M12 or larger; getting a real engineer involved is a good idea.  The taller the pipe, the more you need it to be done correctly.
John Fruits
« Reply #16 on: August 25, 2017, 07:00:55 pm »
For those who haven't seen it, another fun truss option which offers many configuration possibilities:
http://www.modtruss.com/
The last few years they have shared a booth at LDI with Blizzard Lighting.
Page created in 0.044 seconds with 22 queries.
