Author Topic: bases for truss and pipe in one?  (Read 4191 times)
(Brian) Frost
« on: August 24, 2017, 12:31:12 pm »
i really like aluminum 30" bases for truss.  I would love my inventory to be all the same bases.  are there aluminum bases that have threads for pipe and also work for global truss?
Nathan Riddle
  • Niceville, FL
    • Nailed Productions
Re: bases for truss and pipe in one?
« Reply #1 on: August 24, 2017, 12:45:01 pm »
Make your own?
(Brian) Frost
« Reply #2 on: August 24, 2017, 01:08:20 pm »
Make your own?
how would  I safely attach the threaded piece?
Dave Barker
« Reply #3 on: August 24, 2017, 01:13:45 pm »
Bolt one of these to the bottom of your base plate, screw in the pipe.  Shouldn't interfere with your trussing.  I prefer steel base plates when using pipe just use lots of sandbags.
http://www.homedepot.com/p/1-1-2-in-Galvanized-Malleable-Iron-Floor-Flange-511-607HN/100183709
(Brian) Frost
« Reply #4 on: August 24, 2017, 01:27:35 pm »
You wouldnt be worried that the torque of a 12ft pole could rip any smaller bolts out of that adapter?
Nathan Riddle
  • Niceville, FL
« Reply #5 on: August 24, 2017, 02:03:59 pm »
12ft pole * 30lb force at top = 360lb/ft moment
your run of the mill 1/4" bolt has 1750lb loading and 2350lb tensile strength.
I doubt you'll have issues. I'd be more concerned the bolts on the bottom of the plate protruding. (just countersink them...)
http://www.almabolt.com/pages/catalog/bolts/proofloadtensile.htm
TJ (Tom) Cornish
  • St. Paul, MN
« Reply #6 on: August 24, 2017, 03:08:15 pm »
As this hasn't been mentioned yet, drilling and tapping your base for pipe threads isn't a good idea - not enough thread surface, and the aluminum base plate isn't strong or thick enough to have enough holding force - you would rip the threads right out of the base.
If you're going to do it, a flange bolted to the plate is the way to go.
(Brian) Frost
« Reply #7 on: August 24, 2017, 03:54:22 pm »
agree.  i was worried that the flange wouldnt have enough threads either.  i wonder if i got a plate that had a lip around the edge and put a hole through the plate and had the flange on the under side.
TJ (Tom) Cornish
  • St. Paul, MN
« Reply #8 on: August 24, 2017, 05:01:18 pm »
You haven't said what this is for.  What is the application?  The flange will be significantly stronger than the aluminum plate.
(Brian) Frost
« Reply #9 on: August 24, 2017, 06:08:08 pm »
i want to be able to use the same bases for truss with projectors on top and poles with lighting on top.  if it seems safe,and i can do both from the same location,  Id like to have an offset pole threads so I can put a projector on a top plate and 2 lekos on a pole on one base.
All of this would be very light weight.  50lbs for projector, 50 lbs for 2 lekos.
Page created in 0.094 seconds with 24 queries.
