Author Topic: ground loop woes  (Read 3393 times)
Paul Graves
ground loop woes
« on: August 15, 2017, 05:08:07 pm »
Our setup:
X32 and an analog mixer located in different places and different AC circuits.
Two large powered speakers with built in two channel mixer, each again different AC circuits
Impossible to get all on one or even two AC circuits.
Each mixer has its Left and Right connected to the powered speakers.
I am fairly certain it is ground loop causing hum, I ran some tests connecting and disconnecting and actually I believe there are several loops. Don't want to expose or person or  the equipment to risk of damage by doing something stupid.
Solutions I am considering .
1) Putting a isolation transformer each XLR cable feeding the powered speakers.
2.) Using a barrel ground lift on each XLR cable feeding the powered speakers/
Any thoughts or experience and also what would be best with our new Behringer X32 rack?
Thanks,
Paul
g'bye, Dick Rees
  • Duluth
Re: ground loop woes
« Reply #1 on: August 15, 2017, 06:13:47 pm »
It might help to use one mixer foor the feed and the other as a sub-mixer via the main mixer.  X-32 would do for the main mixer and let you use more of the processing power over the entire setup.  Scenes, user permissions, etc. as well as fewer points to isolate.
« Last Edit: August 15, 2017, 06:51:13 pm by dick rees »
Mark Cadwallader
  • Helena, Montana USA
« Reply #2 on: August 15, 2017, 06:41:46 pm »
Option #1 is my vote (of the two).
Don T. Williams
    • Q Systems Music & Sound
« Reply #3 on: August 15, 2017, 06:47:06 pm »
Radial Engineering and other companies (Sescom and Whirlwind I think) make combining transformers that will isolate the two mixers from each other.  In my opinion, the use of one of these transformers is probably the best and easiest solution.
The other possible solution would be to feed the two mixers into a third mixer's line level inputs.  The third mixer would actually send the signals to the loudspeakers, but this increases the chance of a ground loop because you are adding more possible places for a ground loop to occur.  A mixer with transformer inputs and outputs would be preferable, but you will still probably have to lift grounds (a combination) to get rid of the hum.
Keith Broughton
  • Toronto
« Reply #4 on: August 15, 2017, 07:15:53 pm »
My vote is for #1 too
Paul Graves
« Reply #5 on: August 15, 2017, 07:36:23 pm »
The mixers are far from one another really can't connect them
Thanks!  Here  is a schematic. I am leaning towards (2) two channel Ebtech  Humbuster ISO transformers as shown in the schematic. Is an Ebtech a good choice in the reasonably priced ones?
g'bye, Dick Rees
  • Duluth
« Reply #6 on: August 15, 2017, 07:53:20 pm »
I have a few EbTech HE-2-XLR's I use for interfacing various systems as needed.  You could use them at the two mixers directly after the output and not have to have single channel units in the middle of the runs.
Paul Graves
« Reply #7 on: August 15, 2017, 08:05:34 pm »
Yes, that is exactly what I was thinking putting that same EbTech unit in each equipment rack with a short cable to L/R out of mixer then on to each speaker. Do you notice much loss of signal with these EbTechs? Do you find they remove the hum effectively?
« Last Edit: August 15, 2017, 08:07:54 pm by Paul Graves »
g'bye, Dick Rees
  • Duluth
« Reply #8 on: August 15, 2017, 08:18:33 pm »
You shouldn't lose any signal through the transformers.
I'm curious, though, as to how this layout came to be and how it's used.  Something just doesn't feel right...
« Last Edit: August 15, 2017, 08:31:31 pm by dick rees »
Paul Graves
« Reply #9 on: August 15, 2017, 08:55:29 pm »
The layout is really a result of budget. The old mixer and speakers came first and are used for the existing permanent install of lectern mic, choir mics and wireless pastor mics. Then cames the new digital mixer to add a band since our church is moving towards contemporary music and a new mixer was needed, so we got a digital one. Ultimately the old analog mixer will go and we probably relocate the digital mixer in place of the old analog and add a digital snake or two.
Page created in 0.08 seconds with 23 queries.
