Author Topic: Amplifier questions.....  (Read 10179 times)
Debbie Dunkley
  • Central North Carolina
Re: Amplifier questions.....
« Reply #50 on: May 11, 2017, 08:22:38 pm »
I was looking at that or maybe an Xrack. Another alternative I was considering is the QU-Pac.
I went with the QU Pac as my second mixer as I already owned and still own the QU16. This means I can share  scenes and shows between the 2 mixers in seconds, I could slot either into place quickly if the other failed at a show, the learning curve was very easy as I already knew the QU16 inside and out and if I do need 32 channels, along with my D- snake ( which I can use with either mixer), I have them using the QU Pac.
Lastly, I like the fact I can still mix from the QU Pac if wifi goes down.
I was tempted to go for one of the other rack options but paid little more and got much more benefit for my purposes. The SB wasn't out then but I still like having a screen on the QU Pac.
« Last Edit: May 12, 2017, 11:45:58 pm by Debbie Dunkley »
Jesse Gregorio
« Reply #51 on: May 11, 2017, 08:34:16 pm »
I went with the QU Pac as my second mixer as I already owned and still own the QU16. This means I can share  scenes and shows between the 2 mixers in seconds, I could slot either into place quickly if the other failed at a show, the learning curve was very easy as I already knew the QU16 inside and out and finally, if I do need 32 channels, along with my D- snake ( which I can use with either mixer), I have them using the QU Pac.
After reading your reply, it reinforced my thoughts in to considering the QU-Pac more than the xRack. It makes way better sense to go that route being that I'm already familiar with the QU-16. I love my QU-16.
Unfortunately these damn things called bills keep getting in the way..... :(
« Last Edit: May 11, 2017, 08:37:08 pm by Jesse Gregorio »
Steve Ferreira
« Reply #52 on: May 12, 2017, 09:59:31 am »
If the OP will be using the limiters and processing in the amp then just get the "bigger" amp. Better to have the extra power and not use it.
Pages: 1 ... 4 5 [6]   Go Up
Page created in 0.054 seconds with 22 queries.
