Pages: 1 2 [3]   Go Down
Author Topic: Mid/highs to use with 4 dual 18" subs  (Read 4525 times)
RichardStringer
Re: Mid/highs to use with 4 dual 18" subs
« Reply #20 on: May 10, 2017, 11:20:18 am »
Considering your budget, you are going to have a hard time meeting your expectations IMO.  Big boy rigs come with big boy price tags.
Ok I guess i'm screwed then, thanks anyway.
Dave Pluke
    • BIGG GRIN Productions
« Reply #21 on: May 10, 2017, 08:45:45 pm »
I have in the past seen used Turbosound TQ440 cabs for about 1,000 do you think a pair of thoae woll be loud enough?
So much depends on your particular situation.  It's difficult to make any accurate predictions.  That said, the specs say: "Maximum SPL (peak) measured with music program at stated amplifier power shall be 137dB." , which is pretty darn loud.
Will 60 degree horizontal coverage (per cabinet) be sufficient?
Dave
« Reply #22 on: May 10, 2017, 08:51:00 pm »
How loud do you need it to be?  That is where you should start when finding the right tool for the job.
I need ### db SPL @ # weighting @ ## distance.  Then you can work backwards to see if a particular speaker will work for your intended application. Then all you have to do is wade through the inflated specs on most speakers and determine how well they will actually perform in your given situation.
And when "doing the math" don't forget to add (subtract-depending on how you look at it) 15-20dB for dynamic range.
DO NOT expect a loudspeaker rated for 130dB peak @ 1M to be able to read that 130dB at 1M with music with a normal SPL meter.
With "canned music" it will typically be 10-15dB below that.  Live typically requires a wider dynamic range
« Reply #23 on: May 10, 2017, 09:40:39 pm »
Some 12 inch tops with 1 inch hf can take all a Powersoft k10 can give. So dont generalize.
Yeah, you can warm your hands on cold night with them....
I'd rather have a low distortion, high efficiency loudspeaker system than a glorified space heater, but I'm kind of old fashioned that way.
RichardStringer
« Reply #24 on: May 11, 2017, 03:38:01 am »
I play dance music not live music though, techno to be precise but thanks, yeah I have noticed in the past that with my old Class 2 spl meter I used to have it measured about 12-15db below what I thought it might.
Randy Pence
  • Berlin, Germany
« Reply #25 on: May 11, 2017, 06:02:06 pm »
not to mention calculated peaks..
Don T. Williams
    • Q Systems Music & Sound
« Reply #26 on: May 12, 2017, 05:09:19 pm »
Are those cabs loud enough then to keep up spl wise with 4 double 18" subs?
The best answer is "it depends".  I know your have already seen discussion about that.
I have not used the subs you have, but my experience with other Warfedale Pro speakers indicates to me that the are prosumer products at best.  I could be wrong about the models you have, but with good amps, DSP settings, and bi-amped properly, this is a serious loudspeaker for it's size.  My guess is "yes", it should keep up.
Pages: 1 2 [3]   Go Up
Page created in 0.057 seconds with 22 queries.
