Pages: [1] 2 3  All   Go Down
Author Topic: Building Powercon Stage Stringers  (Read 7450 times)
Mike Sullivan
« on: May 03, 2017, 11:23:07 pm »
I'm getting ready to build some new stage stringers but plan to make the system a little more modular and take up less space.  The plan is to make boxes with Powercon in & out, with a second out for a pass through to drop boxes for opening acts that can be removed for headlining acts, as well as take less space up on small shows.  I think OA Windsor (under the new owners) makes them, but I was wondering if anywhere else would be a good source to look.  As always cheaper is better, but I'd rather pay for good quality, or try to make my own with standard rubber or plastic boxes.
When you're reading a topic, and the word "Danley" comes up...RUN!!!
Brian Adams
    • Adams Production Services
Re: Building Powercon Stage Stringers
« Reply #1 on: May 04, 2017, 12:11:27 am »
I'd recommend OA Windsor for anything they sell. I don't think you can beat the price and quality anywhere.
Brian Adams
Vermillion, SD
adamsproductionservices.com
Ed Hall
  • Lansdale, PA
« Reply #2 on: May 04, 2017, 07:37:23 am »
+1 for OA Windsor
I just received some for a trial and they are great. If what you're looking for isn't listed, contact Jim and he will work with you to make what you need. Nice guy too.
I can't change reality just because you don't like it!
Mike Sokol
« Reply #3 on: May 04, 2017, 08:01:34 am »
+1
Mike Sokol
mike@noshockzone.org
www.NoShockZone.org
Mark Cadwallader
  • Helena, Montana USA
« Reply #4 on: May 04, 2017, 10:05:39 am »
Mike, I have some of the O.A. Windsor powerCON in/thru quad boxes, which are a standard item. I've made up powerCON cords (12/3 SOOW) in various lengths for the box-to-box spacing. You might consider (as an alternative to custom boxes) just using a short 5/15P to powerCON jumper and plug the opener's quad box into one of the 5/15R spaces on the headliner's quad box.
Edit:  correct spelling/typing error
« Last Edit: May 04, 2017, 05:30:07 pm by Mark Cadwallader »
Mike Sullivan
« Reply #5 on: May 04, 2017, 10:57:45 am »
Mike, I have some of the O.A. Winsor powerCON in/thru quad boxes, which are a standard item. I've made up powerCON cords (12/3 SOOW) in various lengths for the box-to-box spacing. You might consider (as an alternative to custom boxes) just using a short 5/15P to powerCON jumper and plug the opener's quad box into one of the 5/15R spaces on the headliner's quad box.
I could do that but I kind of want to stick with Powercon if I can to make sure that power isn't lost by someone walking across the back or something like that.  Thanks guys, I'll more than likely stick with OA Windsor
William Schnake
    • Schnake Sound & Light
« Reply #6 on: May 04, 2017, 04:03:45 pm »
Mark, could you PM me a picture of the box you are talking about, or just post one here.  I love the OA Winsor stuff and have been thinking of adding a powerCon stringer to my collection.  You can never have to many stringers.  One of the things that I love about OA Winsor is that they can build anything electrical as long as you can describe it.
Thanks
Bill
Bill Schnake - Owner Schnake Sound & Light
Avid/Crown/EAW/EV/Midas/RCF/Shure/Yamaha
schnakesound.com
Mark Cadwallader
« Reply #7 on: May 04, 2017, 05:28:42 pm »
Thanks
Bill
PM sent.
Ed Hall
  • Lansdale, PA
« Reply #8 on: May 04, 2017, 09:09:55 pm »
I just received this from OA Windsor. I ordered one as a test and will be ordering more shortly.  I use the Powercon True 1 connector. Jim made the modification from the stock Powercon stringer box. Everything fit in nicely and works great. It is very solid.
I have several different lengths of 12/3 with True 1 connectors. I can place the stringers where ever needed.
Mike Sullivan
« Reply #9 on: May 06, 2017, 02:11:35 am »
That's what my plan is.  I'll have short pieces of 14/3 (mostly because I got a hell of a deal on the wire) and some longer pieces of 12/3... the short ones will be for backline only so being a slightly smaller wire won't hamper it much.
Pages: [1] 2 3  All   Go Up
Page created in 0.031 seconds with 22 queries.
