Author Topic: Terrific USB cable that plugs in either way  (Read 3827 times)
Pete Erskine
    • Best Audio
« on: April 28, 2017, 11:59:53 am »
Keith Hall showed me this at NAB.  Got one and it is truly amazing.  The Connectors do not have an up or down side - they plug in either way like a Lightning cable.  Testing one in daily use for a couple of weeks and if it survives, I am chucking all my micro USB cables
Micro USB universal
Pete Erskine
917-750-1134
www.bestaudio.com
peter@bestaudio.com
Keith Broughton
  • Toronto
Re: Terrific USB cable that plugs in either way
« Reply #1 on: April 28, 2017, 01:31:59 pm »
Micro USB universal
Interesting but isn't this a solution looking for a problem?  ;)
Stephen Kirby
« Reply #2 on: April 28, 2017, 02:14:55 pm »
USB-C is already out and showing up in products.  It goes either way and supports more power for faster charging of devices.
Pete Erskine
    • Best Audio
« Reply #3 on: April 28, 2017, 03:01:35 pm »
This solves a problem - - I bet that all of you have plugged in a micro usb and had to turn it over 50% of the time.  Same for USB A - the jack on the equipment isn't always in the same orientation between equipment - the label on the plug helps but you need to look carefully at the jack first.  Sure usb C is great but phones, misc computer equipment, charge ports on Freespeak all use micro usb.
Pete Erskine
917-750-1134
www.bestaudio.com
peter@bestaudio.com
Keith Broughton
  • Toronto
« Reply #4 on: April 28, 2017, 03:11:05 pm »
Not so much of a "problem" that I would toss cables and spend more $$.
Same "problem" with AC plugs  ;)
Tim Weaver
  • College Station, Texas
    • Daniela Weaver Photography
« Reply #5 on: April 28, 2017, 04:00:32 pm »
I find that it takes 3 attempts to get it right. Try it, doesn't fit. Flip it over, still doesn't fit. Flip it again, it goes right in. Wth?!?
Do they make 3 sided usb cables?
Jeff Lelko
  • Cape Canaveral, FL
« Reply #6 on: April 28, 2017, 07:00:51 pm »
I'm glad I'm not the only one with this problem!
Brian Jojade
« Reply #7 on: April 28, 2017, 07:53:52 pm »
Compliant USB cables will have the USB logo on the top side of the connector.  For horizontally positioned USB devices, you should be able to feel the USB logo and then insert the connector with no problems.
The reversible connectors are neat, but word of caution. They can be extremely fragile, and while they work in most devices, they do not work in ALL devices. The result can occasionally be an intermittent connection.
Brian Jojade
Pete Erskine
    • Best Audio
« Reply #8 on: April 28, 2017, 10:00:27 pm »
However the mating USB connector on computers, and other devices like hubs and freespeak do NOT have a standard orientation.
Fragility is a mater of manufacturing, I agree.  Some cables, like all, are just junk and others are terrific.  Time and testing will tell.
Pete Erskine
917-750-1134
www.bestaudio.com
peter@bestaudio.com
Pete Erskine
    • Best Audio
« Reply #9 on: April 28, 2017, 10:03:25 pm »
My experience is that I NEVER have the orientation right, so in an attempt to plug it on the first try, I orient the connector opposite to what I think, first.   HAHA - success is not there either.  Triple sided is the solution.
Pete Erskine
917-750-1134
www.bestaudio.com
peter@bestaudio.com
Page created in 0.052 seconds with 22 queries.
