Pages: 1 2 [3]  All   Go Down
Author Topic: Yamaha 01V No sound from Stereo XLR Put and 2TR RCA Out  (Read 7280 times)
brian maddox
  • HeyYahWon! ttsss! ttsss!
Re: Yamaha 01V No sound from Stereo XLR Put and 2TR RCA Out
« Reply #20 on: December 21, 2017, 11:33:53 am »
Problem now solved.
It appears that some Yamaha DAC chips can cause issues. I stripped the unit down and removed the board containing the DAC. The chip is a BB PCM1702U.
Ordered a new one, removed old, soldered replacement in its place and put it all back together.
Both output channels now working again.
Total cost of 15. Would have been cheaper to order the chip from overseas but I wasn't prepared to wait weeks. They are not easy to find (for the original BB chip).
It seems that Yamaha Clavinovas suffer from this lost output problem and replacing this chip is the answer.
A factory reset is needed following replacement of this chip.
Hope this helps anyone else with similar issues.
Kev
Well it may be a zombie thread, but this is valuable new info for those still rocking these old beasts.  So thanks for the contribution!
brian maddox
bdmaudio@gmail.com
noel kehoe
« Reply #21 on: May 28, 2018, 02:06:59 am »
thank you for your post on the forum
i have a similar issue
2tr rca goes mono
main out xlr goes mono
but also monitor out goes mono
i have downloaded manual and taken the ada board out
i see there are 2 pcm1702u ic502 and ic503
do i need to replace both
i only ordered 1 so not sure whether to change both
your help would be greatly appreciated
kind regards noel
Problem now solved.
Kev
  • Old enough to know better
  • Audio Plumber
Posting Rules
« Reply #22 on: May 28, 2018, 10:39:54 am »
admin
Posting Rules
Pages: 1 2 [3]  All   Go Up
Page created in 0.111 seconds with 20 queries.
