Author Topic: one screwdriver mic clips  (Read 4809 times)
Weogo Reed
  • Western NC,
    • LiveEdge
« on: February 17, 2017, 03:24:16 pm »
Hi Folks,
I really appreciate manufacturers that make mic clips that can be snugged up with one straight blade screwdriver.
One philips screw is ok too.
I have a few clips that can be tightened with a dime(small, thin coin).
But requiring two screwdrivers doesn't make sense to me.
Does a two-screwdriver setup really cost that much less to make than a single?
Is there any good reason for this?
Thanks and good health,  Weogo
Jay Barracato
  • Solomons, MD
Re: one screwdriver mic clips
« Reply #1 on: February 17, 2017, 03:46:26 pm »
Audio Technica are single slot
Sent from my XT1254 using Tapatalk
Jay Barracato
Tim Weaver
  • College Station, Texas
    • Daniela Weaver Photography
« Reply #2 on: February 17, 2017, 07:57:47 pm »
idk about screwdrivers but the greatest thing I ever did was file a flathead tip onto my one-handed knife after I broke the tip one day. Nothing greater than whipping out your pocket knife to tighten that clip right away!
frank kayser
« Reply #3 on: February 26, 2017, 10:51:05 am »
I find the two-screwdriver adjustment dangerous.  Especially, straight blade - easy to slip against the opposing hand, also wielding a pointed implement.
Jim McKeveny
« Reply #4 on: February 27, 2017, 08:29:08 am »
And at eye-level.
Clips like these are conceived in a intellectual vacuum. Normal field adjustment requires 2(2!) matching/similar tools, applied in an unnatural and unsteady manner (already on stand), and with time constraints(because "tightening under-designed, loose-ish,  crappy, mic clips" is not a line-item/coded-in factor).
Look ahead. Junk is junk. Nip it in bud. Little things normally don't count... until they do in a big way. Bottom Line: Nobody gets hurt on my stages!
BTW- I attended a C/M Hoist Class @ Mountain Productions @1993 and was given the moniker "OSHA Man" by classmates because I noted some less-than-safe common practices.
Most shit doesn't just "happen". It is allowed to happen.
« Last Edit: February 27, 2017, 08:36:30 am by Jim McKeveny »
John Halliburton
« Reply #5 on: February 27, 2017, 08:34:16 am »
And at eye-level.
Clips like these are conceived in a intellectual vacuum. Normal field adjustment requires 2(2!) matching/similar tools, applied in an unnatural and unsteady manner (already on stand), and with time constraints(because "tightening under-designed, loose-ish,  crappy, mic clips" is not a line-item/coded-in factor issue).
I put up with it, as I still believe the Shure clips are the best out there period.  Two dimes and they're tight.
Best regards,
John
Jim McKeveny
« Reply #6 on: February 27, 2017, 08:46:40 am »
I love you John. But I disagree:
Numero Uno: Dimes? Shure clips are only used in USA?
Dos: Even if we are talking about state-nonspecific currency, in this plastic-beats-cash world, and with all kinds of travel restrictions, who? has/keeps coins around??
  • Old enough to know better
  • Audio Plumber
Re: one thin dime mic clips
« Reply #7 on: February 27, 2017, 11:07:32 am »
The guy that uses them to tighten mic clips? Do you know of a suitable alternative that costs less than 10 cents and fits in your pocket without bulging?
Tim Tyler
  • Richmond, Va USA
« Reply #8 on: February 27, 2017, 11:13:26 am »
http://www.sears.com/craftsman-offset-ratchet-screwdriver-set/p-00904116000P?sid=IDx01192011x000001&gclid=CjwKEAiAuc_FBRD7_JCM3NSY92wSJABbVoxBxwJrX7Ei1RMTpKnfwWhd3Zk-pY6z8ZvK8DL1iY7SFhoC3Zvw_wcB&gclsrc=aw.ds
A pair of these (or similar).  Not just for mic clips...
-Tim T
Jim McKeveny
« Reply #9 on: February 27, 2017, 11:16:56 am »
Perhaps I have been de-contenting for fly-ins too long. No socks. No computer. No change.
Your observation is duly noted!
« Last Edit: February 27, 2017, 11:24:08 am by Jim McKeveny »
Page created in 0.161 seconds with 22 queries.
