Author Topic: Cisco SG300-10 Switch for Yamaha QL5 & Dante  (Read 5383 times)
TomBoisseau
« on: February 02, 2017, 05:12:54 pm »
I'm about to purchase my first Cisco SG300-10 switch for use with a Yamaha QL1 and QL5.  The problem is that there seems to be MANY choices within this same product line (see the link below and the click "View All").
The features I want are:
10 ports
PoE
But, even then there appears to be a few different versions.  Could someone please assist me in choosing?
Thanks,
Tom
http://www.cisco.com/c/en/us/support/switches/small-business-300-series-managed-switches/tsd-products-support-series-home.html
Nathan Grater
Re: Cisco SG300-10 Switch for Yamaha QL5 & Dante
« Reply #1 on: February 02, 2017, 07:25:33 pm »
They are great switches. This is my understanding of of the differences:
SG300-10 - no POE
SG300-10P has 8 POE ports but is limited to 15W/port and total of 64watts
SG300-10MP has 8 POE ports but is limited to 15W/port and total of 124watts
SG300-10MPP has 8 POE ports but is limited to 30W/port and total of 124watts
TomBoisseau
« Reply #2 on: February 02, 2017, 08:00:54 pm »
SG300-10 - no POE
Ah! Okay.  That helps a lot.
Thanks so much.
I'm inclined to purchase the model with the highest wattage for PoE with 10 ports.  I suspect while I might not need it now, in the future I'll probably glad I spent the few extra dollars.  I'm leaning towards the SG300-10MPP which is 124W (PoE+ supported).  What do you think?  Any comments?
I see there is a comparison chart with specs here:
http://www.cisco.com/c/en/us/products/collateral/switches/small-business-smart-switches/data_sheet_c78-610061.html
« Last Edit: February 02, 2017, 08:10:08 pm by TomBoisseau »
Ade Stuart
« Reply #3 on: February 03, 2017, 08:54:44 pm »
Personally, I find the 10 port Cisco SG300 with POE a pain to package. You can rack mount them but there is a large external power supply.
TomBoisseau
« Reply #4 on: February 04, 2017, 08:46:19 am »
You make a good point, and I am aware that many prefer to get the rack mount version with 20 ports or more.  For my application, this unit will never be in a rack and, I just prefer to have a smaller footprint.
Thanks,
Tom
TomBoisseau
« Reply #5 on: February 04, 2017, 09:52:38 am »
Are there any concerns plugging non PoE devices into the PoE ports of the SG300-10MPP?  For instance a console, Rio box, or another non PoE switch?
Ade Stuart
« Reply #6 on: February 04, 2017, 10:36:45 am »
I haven't seen any problems connecting QLs, Rios, WAP and other switches. I've never felt the need to check but I suspect POE is configurable by port on the SG300 and I believe POE is only supplied after handshaking.
  • Old enough to know better
  • Audio Plumber
« Reply #7 on: February 04, 2017, 10:42:03 am »
I wonder how handshaking works when one of the devices hasn't been powered up yet...
Philip Roberts
  • Church and H.O.W. Forums
  • South West MI
« Reply #8 on: February 04, 2017, 12:03:13 pm »
A Powered Device has a 25k resistor across the powered pair(s) when powered off. Higher or lower resistance means that power isn't supplied.
High power modes are negotiated after an initial low power startup.
Philip
Ade Stuart
« Reply #9 on: February 04, 2017, 12:16:38 pm »
An active device can interrogate a passive device before the interrogated device is powered. This is a protocol that is used in electric vehicle charging for example but now we are off topic...
Page created in 0.039 seconds with 22 queries.
