Author Topic: Low Lying Fog  (Read 3138 times)
Steve Alves
  • South Florida
    • South Florida Sound
Low Lying Fog
« on: December 19, 2016, 08:23:25 am »
I have been looking at low lying fog machines for awhile. Happened to go to a TSO show last week and whichever one they are using seemed to work pretty well. Any thoughts or suggestions on machines to look at or stay away from? Not really looking to use a co2 one but some of the all in ones are interesting.
« Last Edit: December 19, 2016, 02:48:21 pm by Steve Alves »
Steven Alves
South Florida Sound, Fort Lauderdale, FL
www.southfloridasound.com
Brook Hovland
    • DiA Events
Re: Low Lying Fog
« Reply #1 on: December 19, 2016, 09:21:53 am »
I have been looking at low lying fog machines for awhile. Happened to go to a TSA show last week and whichever one they are using seemed to work pretty well. Any thoughts or suggestions on machines to look at or stay away from? Not really looking to use a co2 one but some of the all in ones are interesting.
We have some Antari ICE machines and have had good results if you don't want to mess with dry ICE or C02.
« Last Edit: December 19, 2016, 01:39:07 pm by Brook Hovland »
Re: Low Lying Fog
« Reply #2 on: December 19, 2016, 10:41:10 am »
TSA?  I've accused them of practicing "security theatre" at the airports but I've never seen a whole show.
If you mean Trans Siberian Orchestra... I can tell you it involves liquid CO2.
Most of the ground-hugging fog effects traditionally involve dry ice, hot water, fans and big hoses.
Steve Ferreira
Re: Low Lying Fog
« Reply #3 on: December 19, 2016, 11:43:50 am »
I have this Ultratec Unit. http://www.ultratecfx.com/Products/low-lying-fog/dry-icer Works great for weddings and such. How big of a space are you trying to cover?
Rob Gow
Re: Low Lying Fog
« Reply #4 on: December 19, 2016, 01:11:33 pm »
I have a Chauvet Nimbus dry ice machine. It works pretty good.
http://youtu.be/vu9ZzZGY3Gs
Steve Alves
  • South Florida
Re: Low Lying Fog
« Reply #5 on: December 19, 2016, 02:49:37 pm »
Duhh.... I fixed it.. That will teach me to read news stories prior to posting.
So TSO is using the co2 machines?? Do you know which ones?
Steven Alves
Steve Alves
  • South Florida
Re: Low Lying Fog
« Reply #6 on: December 19, 2016, 02:52:00 pm »
I have a Nimbus. The problem is they are not very cue friendly. The second you load them, even with the arm up.. You get effect. I need something that I can cue to start without it fogging while it is being loaded.
Steven Alves
Jeff Lelko
  • Cape Canaveral, FL
Re: Low Lying Fog
« Reply #7 on: December 19, 2016, 04:32:58 pm »
Yes, I'd too be curious to hear how they pull off their effects!
John Chiara
Re: Low Lying Fog
« Reply #8 on: December 19, 2016, 05:39:22 pm »
I thought years ago there was a home brew setup for running chemical fog through a cooling unit.
duane massey
Re: Low Lying Fog
« Reply #9 on: December 19, 2016, 07:45:11 pm »
If you're doing a small stage and want a short-term effect I used to use the ADJ Mr Kool. Uses regular ice, regular fog fluid. If you're a DIY person, you can just get a large Igloo chest, cut a hole on each end towards the top, fill it halfway up with either ice or dry ice, and use almost any fog machine. Won't be as thick or heavy as CO2 but can be effective.
In the 80's we built our own dry ice machine, using two 55gal barrels stacked. The top barrel held the ice and dispersion tubes, bottom had heating elements and a pump. A remote relay triggered the pump and sprayed the hot water on the dry ice, and the water drained back into the bottom tank to be reheated. We could use it 2-3 times a night on a large stage and generate 2-4' high layers of fog. PITA, but very, very efeective.
Duane Massey
Houston, Texas
Re: Low Lying Fog
Page created in 0.053 seconds with 23 queries.
