Author Topic: Avid Profile Waves V9.1 licenses v9.2 won't work.  (Read 4387 times)
Al Rettich
« on: December 09, 2016, 09:21:14 pm »
Anyone else have a issue with Waves V9.1 installed o. A Avid Profile plug in USB key with licenses version 9.2 the plug ins says it can't see the licenses Yes, Waves is enabled. Going to try and reinstall Waves tomorrow.
Justice C. Bigler
  • back home in Oklahoma
    • My homepage
Re: Avid Profile Waves V9.1 licenses v9.2 won't work.
« Reply #1 on: December 09, 2016, 09:36:48 pm »
Are you still trying to use the iLok? Waves moved away from iLok with version 9 I believe. Have to use a USB key, not sure if Avid supports that or not on their live consoles.
Justice C. Bigler
www.justicebigler.com
« Reply #2 on: December 09, 2016, 09:41:16 pm »
We have the last version of TDM for Venue Waves, 9.something.  My licenses are on a conventional USB thumb drive.
Nikhil Mulay
« Reply #3 on: December 09, 2016, 10:25:44 pm »
It's happened to me before.. Try removing and putting back the licences in the thumb drive.. Also as a precaution write protect the license file. Works for me so far.
Sent from my SM-G900F using Tapatalk
John Sulek
  • Toronto Canada
« Reply #4 on: December 09, 2016, 11:27:57 pm »
Last time I had a problem with a licence not being recognized, the Waves support folks told me to put it on a smaller (1GB) usb key and try that. Same licence file on a small capacity key worked fine.
Kevin Thurber
« Reply #5 on: December 14, 2016, 10:07:16 am »
Were you ever able to find the cause or solution for this?
Al Rettich
« Reply #6 on: December 14, 2016, 03:37:04 pm »
Was never able to get it to work. Even uninstalled, then installed a newer version of Waves plug ins. Key never saw it. I did talk to someone and he said if you use the license for a native plug in then it's never going to work on the Avid Soundgrid plug ins. Not sure if that's true, but I'll keep trying to get it working.
« Reply #7 on: December 14, 2016, 04:29:47 pm »
Contact Waves... there is no longer a distinction between Native & Soundgrid/TDM licenses (other than no new TDM plugs are coming).  A couple years ago they were advising users to contact Waves Central (or whatever the licensing App was) and get new licenses to replace Native/Soundgrid/TDM-only licenses.  If the Venue TDM plugs were updated to the most recent (and final) versions it's possible that 9.2 requires the new license format.
Al Rettich
« Reply #8 on: December 15, 2016, 08:26:11 am »
They were 9.1.0
« Reply #9 on: December 15, 2016, 10:35:56 am »
They were 9.1.0
In that case you should certainly email the support desk at Waves.  They're very helpful.
Page created in 0.052 seconds with 22 queries.
