Author Topic: goo systems  (Read 2892 times)
Micheal Martinez
goo systems
« on: November 09, 2005, 12:55:50 pm »
Has anyone used or at least seen a Goo systems screen.
I have thought about using it on a wall in the church for our projection system. We are currently just projecting on the wall.
Mike
Brian Kent Tennyson
    • http://www.visitec.com
Re: goo systems
« Reply #1 on: November 09, 2005, 08:44:03 pm »
We use Walltalkers quite a bit. Easy to install and has quite a variety of surfaces. Many time clients will pit a frame around it to make it look finished.
http://www.walltalkers.com/
You can't get enough, but enough ain't the test.
Brian Kent Tennyson
Visitec Inc.
www.visitec.com
MIKE HARPER
Re: goo systems
« Reply #2 on: September 28, 2006, 03:34:01 pm »
That is what we plan on using in our new sactuary.  I am pretty close with our sound contractor and he said he uses it all the time.  He showed me some pictures and they looked pretty sweet.
Mike Harper
Calvary Life Church
www.gocalvarylife.com
Brad Weber
Re: goo systems
« Reply #3 on: September 28, 2006, 10:58:14 pm »
I have no direct experience with the Goo Systems products, but the reviews online seem favorable at least as far as it being a good value and a cost effective solution, it definitely would likely be a significant improvement over a typical wall.  There are numerous references to how since it is a paint product the surface preparation is critical and any imperfections in the wall surface will show up in the image, it makes sense that this may be even more of an issue with larger screens areas.  I also noted that most of the photos that Goo shows in their gallery are of applications where there is low level, controlled lighting, the few with some ambient lighting on the screen seemed to show quite a bit of wash.  Unfortunately, some of the pictures on the Goo Systems USA site also appear to possibly have some PhotoShop involvement, such as lacking any fringing around an image that does not fill the screen and in some cases almost a different resolution for the image than the rest of the picture.  I haven't seen anything addressing this aspect, but since the Goo Systems is a multi-coat system of two different products I am curious as to how easy it is to touch-up or repair.
I have several experiences with the WallTalker products. They pretty much do as advertised and are fairly easy to install.  Like any multipurpose product, in this case being both a projection and writing surface, there have to be compromises and the performance for projection will not be the same as with a dedicated projection surface.  It is also a difficult surface to work with if you ever need to remove or repair it, think very heavy wallpaper that is strongly glued to the wall.
You didn't say what size image you are considering, but I look at getting prices for a couple of different options.  If nothing else it may help show what a good steward you are being with the church's money. Smile
Brad Weber
muse Audio Video
www.museav.com
Re: goo systems
Page created in 0.035 seconds with 23 queries.
