Author Topic: Vertec Pin Lubricant  (Read 1486 times)
David Sturzenbecher
  • So. Dak.
    • Sturz Audio
« on: August 05, 2016, 03:51:32 pm »
Hi,
I am getting quite a few of the fly pins on a Vertec rig that are getting sticky and not releasing properly. Any idea what the best lubricant would be for these?
Audio Systems Design Engineer
Daktronics, Inc.
CTS-D, CTS-I
AES Full Member
Ray Aberle
    • Kelcema Audio
Re: Vertec Pin Lubricant
« Reply #1 on: August 05, 2016, 04:15:33 pm »
I have the same problem, and would love a suggestion as well! :)
-Ray
Kelcema Audio
Jay Barracato
  • Solomons, MD
« Reply #2 on: August 05, 2016, 04:39:44 pm »
I would go with powdered graphite ( lock lubricant) because it doesn't pick up dust and dirt.
Sent from my XT1254 using Tapatalk
Jay Barracato
Stephen Kirby
« Reply #3 on: August 05, 2016, 05:11:09 pm »
Has anybody tried this stuff?  http://www.mclubemarine.com/sailkote/.  The miracle dry lube.  Have used it on similar pins on the sailboat along with tons of other uses.  I also use it for bicycle chains as it helps them run as quiet and free as any specialty bike lube but picks up less grime.
John Sulek
  • Toronto Canada
« Reply #4 on: August 05, 2016, 07:39:19 pm »
Hi,
I've used spray teflon lube successfully on these pins on other systems.
Doesn't turn everything into an oily mess. Powered graphite gets messy.
It's also great for the coupling threads on veam connectors.
The sailkote spray looks to be a great solution.
Jim Rutherford
« Reply #5 on: August 05, 2016, 08:41:50 pm »
While I haven't used it for your application, I've used moly lube for a lot of applications requiring extended use.  It comes in several forms.
Riley Casey
« Reply #6 on: August 05, 2016, 08:51:17 pm »
I carry a can of spray silicone lubricant in every truck and every tool kit. Good for what ails ya'.
Page created in 0.027 seconds with 24 queries.
