Author Topic: FS: JBL MR938 3-Way Speakers (Local MA Sale)  (Read 1289 times)
Rob Bernstein
« on: August 01, 2016, 08:47:53 am »
Helping a friend clear out some unused gear.
These were used sporadically for about a year and then put into storage.
They weight 99 lbs each so shipping would not be an option.
Pick-up/audition them outside of Boston, MA (Sudbury).
$600 for the pair.
 The MR938 integrates a 18" low frequency transducer, 10" cone midrange, and a pure titanium compression driver on a Flat-Front
Bi-Radialฎ horn. A larger version of the MR935, it features very warm mid-band reproduction.
FEATURES:
• 3-way with one 460mm 18" SHG Woofer and titanium diaphragm compression driver
• Sonicguard high frequency protection with indicator
• Speakon & phone jacks
• Frequency Range: 38 Hz - 18 kHz (-10 dB)
• Power Capacity: 250 Watts (Continuous Pink Noise EIA RS426A, 8 hrs)
• Peak Pink Noise: 1000 Watts
• Nominal Impedance: 8 Ohms
• Sensitivity: 100 dB (1W, 1m)
• Nominal Dispersion: 100 Horizontal x 80 Vertical
• LF Driver: MR938: 460 mm (18 in)
• MF Driver: MR938: 250 mm (10 in)
• HF Driver: Pure Titanium Diaphragm Compression Driver/Flat-Front Bi-Radial Horn
• Enclosure Material: Oriented Strand Board
• Dimensions: 33 1/4 x 28 1/4 x 18 in
ยซ on: August 01, 2016, 08:47:53 am ยป
Page created in 0.024 seconds with 22 queries.
