Pages: 1 2 [3]   Go Down
Author Topic: Danley SM80 splay?  (Read 7988 times)
John Halliburton
Re: Danley SM80 splay?
« Reply #20 on: July 07, 2016, 08:24:32 am »
We cross our TH 118/SM 80 at 130Hz. It outperforms any KF 650z rig I have ever used.
Kemper Watson would probably say the same-he went from a 650 rig to an SM80 rig as well.
Best regards,
John
Robert Piascik
« Reply #21 on: July 07, 2016, 08:48:39 am »
...went from a 650 rig to an SM80 rig as well.
So did I.
Pi Entertainment Services
Midas M32R / MR18
Behringer X32R / XR12
Fulcrum Acoustic fa22ac
RCF NX 12SMA
Yamaha DSR112 / DZR10
Powersoft X4 / M50Q
Crown iT8k / Xti6k
Jonathan Betts
    • http://www.facebook.com/pages/JLB-Sound-and-Production/156817657745906
« Reply #22 on: July 07, 2016, 09:32:20 am »
Many BE's that run the system are concerned with the tunings I use. They fear there will be lack of and or sloppy low mid punch. Once they start to drive all worries are lost.  Some end up cutting in the 100-120Hz range.
Rick Powell
« Reply #23 on: July 07, 2016, 11:04:33 am »
Here are the actual HP/LP settings I use. This is used with original Crown ITech DSP.
SM80:
HP Butterworth 12db 125Hz
TH118:
LP Bessel 24db 130Hz
Delay 1.25ms
Interesting. I may try re-tuning ours...I am crossing a little lower than that, around 100 Hz, and using a steeper roll off on the SM 80.  Sounds fine like it is, but could maybe squeeze a little extra low-mid juice out of it.
Rick Powell
« Reply #24 on: July 07, 2016, 11:14:51 am »
SM80:
TH118:
Delay 1.25ms
Jonathan:
Are you also reversing the polarity of the subs?  Danley has suggested that it sometimes helps.  Also, isn't it the tops that you are delaying 1.25ms, rather than the subs - to compensate for the delay caused by the horn path of the TH118?  According to Danley, the delayed response of the sub should be somewhere in the range of 3-20 ms.  1,25ms seems short - I think our tops have a delay set around 5ms.
See FAQ #10 on Danley's page.
http://www.danleysoundlabs.com/support/frequently-asked-questions/#question_10
Thanks!
« Last Edit: July 07, 2016, 11:18:18 am by Rick Powell »
Jonathan Betts
« Reply #25 on: July 07, 2016, 12:56:42 pm »
Jonathan:
Thanks!
The polarity is flipped on the TH 118 and yes that delay setting is for the TH 118. We spent a better part of a day tuning the system with SMAART 7 in an open air environment. I also have several EQ filters engaged on both the SM80 and TH 118. Again these tunings were developed using Crown ITech DSP.
Pages: 1 2 [3]   Go Up
Page created in 0.065 seconds with 22 queries.
