Author Topic: A view from the Rx  (Read 4186 times)
Brad Harris
A view from the Rx
« on: May 11, 2016, 01:20:36 pm »
Sometimes you will see or hear mention of "Always look from the standpoint of the receiver" in regards to antenna and downstream devices.
Here is a quick example of why.
This is taken during a show. The first one from the LPDA antenna grid feeding a few racks of Rx, the other, a Dipole in the same physical location (just 16" lower in height) as the grid antenna.
BRad
Nathan Riddle
  • Niceville, FL
    • Nailed Productions
Re: A view from the Rx
« Reply #1 on: May 11, 2016, 03:51:30 pm »
Hey Brad,
Could you help me understand more about your images. I'll admit I know little about RF (just what my EE classes taught me, basics), but I'd like to know more.
Are each of the single line peaks (looks like impulse, but because of scale of your chart is really just a narrow width wireless system freq) a wireless system being used?
Are you trying to document/explain that 'looking' at what the Rx antenna gear receives is a good idea so that you can 'see' extra noise. Rather than looking at whatever test equipment you have 'sees'
Thanks,
Nathan
  • Old enough to know better
  • Audio Plumber
« Reply #2 on: May 11, 2016, 07:45:18 pm »
Hey Brad,
The quieter scan shows how much spurious RF the LPDA (Paddle) antenna rejects compared to a simple whip.
Kevin Graf
« Reply #3 on: May 12, 2016, 07:28:26 am »
Is it a half wave dipole or a quarter wave whip?
Speedskater
Brad Harris
« Reply #4 on: May 12, 2016, 09:00:14 am »
Here is another scan I did this morning to hopefully clear up the image a bit
This Dipole is not a whip antenna (like you would normally find on the front/back of a receiver), rather a wide band omni antenna (in this case a Shure UA860SWB). Most RF manufacturers make a similar antenna (Sennheiser, Telex, etc).
The lower noise floor is from the LPDA which is a directional antenna, whereas the higher noise floor is from the omni antenna. What this signifies, is always look at RF from the receivers point of view (i.e., the antenna that your receiver systems is using whenever possible).
Some exceptions are IFB/IEM as most are 'built in' and can't be 'tapped into', where you would require a separate antenna to monitor what is happening in the spectrum at that position.
BRad
Kevin Graf
« Reply #5 on: May 12, 2016, 12:57:14 pm »
A dipole is far from an omni antenna. Viewed from the ends, it has a null.
That's a real nice frequency read-out.
« Last Edit: May 12, 2016, 01:01:18 pm by Kevin Graf »
Speedskater
Brad Harris
« Reply #6 on: May 12, 2016, 01:09:56 pm »
Yes, if one wasn't talking about antennas. What you are talking about is a theoretical Isotropic antenna.
https://en.wikipedia.org/wiki/Omnidirectional_antenna
BRad
Dan Currie
« Reply #7 on: August 04, 2016, 10:45:13 am »
Really cool stuff!!  What kind of attenuator did you use to protect the scanner from the high level signal of the distribution amplifier?
BRad
Brian J Holder
« Reply #8 on: August 04, 2016, 11:45:40 am »
Brad
I know that curiosity killed the cat, but what device did you capture the images from?
Brian
Karl Winkler
    • Lectrosonics
« Reply #9 on: August 10, 2016, 10:54:17 am »
Interesting images, Brad, and a good illustration of what you are talking about.
Another reason to "see the world from the receiver's perspective" is that receivers, active splitters, active antennas, etc. will all generate intermods where a simple antenna into an analyzer will not. So, in effect, you can see something opposite than your images show, specifically more IM frequencies.
When compared to analyzers, wireless mic receivers are more sensitive but generally not real time and not as wide band. So of course both tools have their place.
In theory, theory and practice should be the same. In practice, they are not.
Page created in 0.027 seconds with 24 queries.
